New QA1 Products!
New QA1 Products!
Double Adjustable Front F-Body Shocks
• Ride Height Adjustable
Directly threaded body allows for stock or
Aluminum shock with 576 valving options.
Allows truly independent adjustment of
compression and rebound. 24 positions of
compression adjustment on one ****, and
24 positions of rebound adjustment on the
other ****. Each **** is clearly labeled with
an "R" for rebound or a "C" for compression,
as well as plus and minus symbols for ease
of adjustment.
Front F-Body Springs
QA1 offers the perfect springs for 1993 - 2002 Camaro/Firebird front
suspensions using the GEN-F front shock. QA1 now offers three spring
choices for your Gen-F vehicle. Purposely built with factory and modified
small block cars in mind, the springs below are designed to set on the
GEN-F spring seat and fit into the factory location at the top. When used
in conjunction with the GEN-F front shocks, they are unmatched in ease
of installation and performance.
- 275 lb. spring Drag Racing
- 300 lb. spring Nice Ride & Handling
- 325 lb. spring Firm Ride, Great Handling & Cornering
Double Adjustable Rear F-Body Shock
compression and rebound. Includes Lower
Shock Bolt (part #7888-108).
Pricing Coming Soon - Preorder with LS1 Speed! - 866-LS1-SPEED
Originally Posted by Dear John
Cheaper than the AFCOs, but why 24 settings? Some of us can't even count to 24. How will we keep track of the settings?
Moderator
I believe they're 315 lb rated.
I thought so as well but if they are then they would fall between the new QA1 springs nice ride and firm ride. If this is the case then why do people complain about their ride when using the OED315 spring?
