PRC 243 LS6/LS2 Complete CNC Ported Heads In Stock!
Old 02-16-2006, 09:29 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default PRC 243 LS6/LS2 Complete CNC Ported Heads In Stock!
Guys we just finished up the backorder of LS6 style cylinder heads & we even have a few sets ready to go together for new orders! Feel free to call or IM me for information on the cylinder heads! They are the same port that went 460+rwhp in NJ & gained over 34rwhp & 26ft lb on a local car!
HP GAINS:
https://ls1tech.com/forums/showthrea...hlight=PRC+LS6
Checkout the bottom of the page for more info on the customer going over 460rwhp with a magic stick!!
The cylinder heads are $899.99 complete with valves & stock LS6 springs.
They are also available with double springs for a additional $250, or $159.99 for Comp Cams 918s
Jason
Texas Speed
www.texas-speed.com
806.866.0734
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-16-2006, 09:38 AM
https://ls1tech.com/forums/dynamometer-results-comparisons/449568-468rwhp.html
468rwhp
__________________
Jason
2005 Twin Turbo C6
Old 02-18-2006, 09:59 AM
1MEANGTO's Avatar
Will those flow enough for a 408 with your giant cam?
Old 02-21-2006, 02:29 PM
camaroguy26's Avatar
I heard they had a bad run with their porting not too long ago, did all this get cleared up?
Old 02-22-2006, 02:10 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I believe you have heard of another CNC cylinder head company having problems. We haven't had problems with the porting or components used---since bringing everything in-house.
Old 02-22-2006, 02:26 AM
DuronClocker's Avatar
PM me a quote shipped to 60108? I just over-revved my motor and may be needing some new heads (possible valve issues...will check out tomorrow in daylight). What kinds of lift are LS6 springs capable of?
Old 02-22-2006, 10:17 AM
Jon@Texas-Speed's Avatar
Shipping is about $38 to you DC I have them in stock incase you need a set quickly The LS6 springs go .550" lift.
I would go big valves if I were going with a 408, the bigger bore on the iron block is just screaming for a larger valve
Old 02-22-2006, 03:25 PM
1MEANGTO's Avatar
Will that hurt my 346 to go with the bigger valves now?
And can I get them minus the valvesprings? I alreay have the prc dual springs.
Have you guys put these on any magic stick equipped cars. just wondering if you have any numbers on a gain for the magic stick and these heads.
Old 03-06-2006, 05:18 PM
1MEANGTO's Avatar
Well i just ordered lots of stuff from tsp and these heads!
Hey we're these in stock?
Old 03-06-2006, 10:57 PM
97 Z Me Go's Avatar
pmed ya!
KYle
Old 03-07-2006, 11:40 AM
99SLOWC5's Avatar
Jason,
you have a PM
Old 03-23-2006, 08:47 PM
4mula's Avatar
how much minus the springs?
Old 03-23-2006, 09:00 PM
AdamSS's Avatar
Those stock 1.55/2.00 valves on you 243 heads, are those the light sodium-filled valves off the corvette Z06 ????
Quick Reply: PRC 243 LS6/LS2 Complete CNC Ported Heads In Stock!
