Amp rack for large amp.
Old 09-10-2005, 04:35 PM
DreamState23x's Avatar
Default Amp rack for large amp.
I was looking at the subthump amp racks but my amp is 17.7"x9.25"x2.36". It wouldn't be able to mount to either side of it.(right side of hatch latch or left side) And I can't tell if the spot under the latch is wide enough(top to bottom) to mount the amp centered under the latch. Any comments or suggestions?
Old 09-11-2005, 12:03 PM
BlkTARebel99's Avatar
why not run it across the whole back?
Old 09-12-2005, 05:24 PM
GPz1100's Avatar
Sounds like my alpine 545 amp. I was able to fit it and a smaller amp on the back with no problems..
pics will follow eventually
Old 09-12-2005, 07:08 PM
methane's Avatar
do what i did.....
http://community.webshots.com/photo/...33518730WtRFew
mount it across the entire back.
Old 09-13-2005, 11:44 AM
GPz1100's Avatar
Ok, here's the promised pics.
Two notes.
1) These are huge images (some nearly 1.5 MB in size), dialup users beware.
2) If you link directly, they will be removed. Please link to this thread.
http://home.comcast.net/~zx1100e5/pics/100_1136.JPG Driver sail panel
http://home.comcast.net/~zx1100e5/pics/100_1137.JPG Passenger sail panel 1
http://home.comcast.net/~zx1100e5/pics/100_1138.JPG Passenger sail panel 2
http://home.comcast.net/~zx1100e5/pics/100_1139.JPG Passenger sail panel cross over
http://home.comcast.net/~zx1100e5/pics/100_1140.JPG amp rack 1
http://home.comcast.net/~zx1100e5/pics/100_1141.JPG amp rack 2
http://home.comcast.net/~zx1100e5/pics/100_1142.JPG amp rack 3
http://home.comcast.net/~zx1100e5/pics/100_1143.JPG amp rack 4
EDIT: After all this work, I still can't fit the pass ttop. The sub is in the way. It will not slide down deep enough into the well to be locked in place.
Edit2: Previous pics http://home.comcast.net/~zx1100e5/pics/
Old 09-13-2005, 12:54 PM
Thanks everyone, I guess i'm just going to mount them veritcal on each side of the latch on the subthump amp rack, instead of horizontal. Thanks again.
Old 09-14-2005, 01:24 AM
GPz1100's Avatar
Dream,
Vertical mounting would work too, but also consider how easy adjustments will be.
You might be able to mount both horizontally, but offset.
How big is your 2nd amp? Or are both the dimensions posted above?
Old 09-14-2005, 12:03 PM
They are both about the same size. If I ount them vertically they will actually be easier to make adjustments to. I'll just mount them with the frequency controls facing up towards the hatch.
Quick Reply: Amp rack for large amp.
