will the crossovers fit underneath the door panels?
Old 11-16-2005, 04:47 PM
02blackws679ta's Avatar
Default will the crossovers fit underneath the door panels?
just curious if there is someplace underneath the door panel that the xover's can be installed?
Old 11-16-2005, 08:01 PM
227Hawk's Avatar
Depending on size you can take silicone adhesive and attach them to the back of the speaker holder before install. Makes wiring easy.
hmm...
Old 11-18-2005, 07:56 PM
98boxer's Avatar
I installed a crossover on the passenger side door panel, but was unable to do this for the driver side. But this was on a camaro.
My crossover was from a componet kenwood speaker, tweeter system. So it was a small crossover. I put one crossover on the top left side of the passenger dooer panel. The other at the driver side, kick panel.
Old 11-19-2005, 01:39 AM
Cali99SS's Avatar
I used a piece of dampening material rolled it into a cylinder and attached it to the back of the crossover and then attached it to the flat part of the door nearest the hinge. You may need to "tape" the wires to the same panel to keep from interfering with the window. Worked for me pretty easy.
Old 11-19-2005, 09:32 PM
ultraz's Avatar
are u kidding me, u can put them in the kick panels and have them out of the way. I have the huge infinity perfect crossovers and they fit in the "pocket" on the passenger side, and i velcroed it on the driver side.......... i may post up a pick to show u how it looked.
Old 11-19-2005, 09:36 PM
post a pic, id like to see how it looked
Old 11-19-2005, 10:00 PM
ultraz's Avatar
there u go
Old 11-20-2005, 08:12 AM
LETHL_SS's Avatar
Yup, did the same thing with mine.
Old 11-20-2005, 11:44 AM
GPz1100's Avatar
The problem with hiding crossovers becomes if they're adjustable - as many highend crossovers are..
Old 11-20-2005, 02:41 PM
ultraz's Avatar
what, do u change ur settings every time u change a CD? usually ull adjust it once or twice and ur done.
Old 11-20-2005, 03:02 PM
GPz1100's Avatar
When I initally set my system up, I played around with different crossover settings for a good 3 weeks until i was satisfied. Since then (5 months ago?) I've tweaked the settings at least twice.
ymmv
Old 11-21-2005, 10:01 AM
01 Red WS6's Avatar
there u go
That's where I would put it.
Old 11-21-2005, 11:54 AM
so what about on the driver's side? isnt the kick panel different?
Old 12-03-2005, 02:12 AM
HavATampa's Avatar
Question
I was thinking the same thing. I'm trying to find a good place for some Diamond Audio crossovers, these things are freaking huge. I might can squeeze it in on the passenger side but the drivers side looks impossible under the kick panel.
Old 12-03-2005, 12:28 PM
i wrapped mine in plastice and put them inside the doors :shrug:
didnt feel like ******* with it else where. everything works great and it all sounds awesome
Old 12-03-2005, 12:49 PM
chrs1313's Avatar
put one of the jl xr series crossover under the steering wheel inside the lower dash flap, other is in the same spot under the dash flap on the passenger side right behind the glove box, both are fairly large and could not find any room in the doors
