ipod question
Old 12-10-2007, 10:19 AM
plopp's Avatar
Default ipod question
please scroll down to #9.... I followed the forum's advice and looked for the code on the circuit board..... I would like to use the GM9-Aux adapter ...
I used the search function and read that the Ipod2car won't work with some 1999 Monsoon systems. Why ?
I have a 1999, how can I find out if the Ipod2car adapter works with my radio ?
As you can tell from this post... i know nothing about these Ipod adapters....
I found this one on Crutchfield's site:
http://www.crutchfield.com/App/Produ...adapter&tp=120
They don't say it doesn't on some 1999 monsoon systems ...
Old 12-10-2007, 11:57 AM
Ungrounded Moderator
WhiteBird00's Avatar
iPod and auxiliary input adapters require the head unit to be capable of controlling the factory external CD changer in order to work. All f-body cassette head units had this capability but CD head units didn't get it until late in the 99 model year. So, if you have a cassette in your 99 then it will work fine. If you have a CD then it might work but it probably won't. The only way to tell if you have an early or late 99 head unit (other than just trying the adapter) is to open up the head unit and look at the stamped code on the CD drive circuit board.
If you go through the "what fits my car" routine on Crutchfield you will get to a page that has an "Important Requirements" link that says "Factory radio must not have indash CD player" for a 99 Camaro (same for Firebird).
Old 12-10-2007, 12:25 PM
plopp's Avatar
Thanks. I have a CD player in this '99. I'll open the head unit and look for the code. What exactly am I looking for ?
Will this GM9-aux adapter (if the head unit supports the port) also charge the Ipod ?
What about this Ipod2car adapter ? Will that work on this 99 HU if the GM9-aux doesn't ??
From what I learned so far a used 2001 HU might be the cheapest and easiest solution....
Old 12-10-2007, 12:44 PM
The code is a printed stamp on the circuit board. The code E-8276-1 does not support a CD changer or any of the iPod/auxiliary input adapters. The code E-8276A-1 does support the changer and adapters.
Not supported:
Supported:
The GM9-AUX is an auxiliary input adapter that provides RCA jacks to connect any external auxiliary source (MP3 player, satellite radio, etc.). It will play music from an iPod but it can't control the iPod or charge its battery.
If your CD head unit doesn't support a changer then none of the adapters will work - iPod2Car, GM9-AUX, nor any others.
Old 12-10-2007, 03:01 PM
sroach20's Avatar
or you could buy something like this: http://www.pioneerelectronics.com/pn...194603,00.html
then youd have direct ipod control and a radio that actually sounds good
Old 12-10-2007, 08:40 PM
plopp's Avatar
GREAT INFO !!
I'll have a look at the circuit board some time this week. Most likely the adapter won't work but thanks for taking the time to reply with photos, I'm sure it'll help other members as well.
Old 12-10-2007, 08:42 PM
plopp's Avatar
Originally Posted by sroach20
or you could buy something like this: url]http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069880_338194603,00.html[/url]
I own this car since 2001. I should have dumped the stock stereo back then....
Old 12-10-2007, 08:57 PM
ginop524's Avatar
i have the usa spec adapter in my 02 def recomend this one works amazing charges the ipod and all and the steering wheel controls work. i dont know if this helps due to your year/model but stay away from the peripheral tried it first 100% garbage
Old 12-19-2007, 07:44 PM
plopp's Avatar
Not supported:
Supported:
OK... I just disassembled the radio today and found code 8276-2..... now what ???
Old 12-20-2007, 08:05 AM
Any chance the head unit was replaced (perhaps under warranty) before you bought the car? It's possible you actually have a newer than 99 head unit in which case the adapter should work. The stamped code certainly seems to be later than the ones shown for 99 models.
I'd be tempted to try it and see. If it doesn't work it won't do any harm. You could always pick up a newer head unit for under $100 from the parts for sale section here or on eBay. That would ensure it working and still retain the factory look.
Old 12-20-2007, 08:40 AM
plopp's Avatar
I bought the car Nov 2001 with only 30K miles... no idea if the head unit was replaced but maybe it was replaced....
The cables for the CD changer were connected to the HU. I wonder if the factory wired and connected the cables even though the CD changer control was not supported
I will try the GM9-aux adapter and a headphone to RCA cable. Hopefully I can find it locally so it's an easy return (without shipping) if it doesn't work.
I also have a '99 tape deck and I'll try that as well with a tape adapter, don't really like giving up on the CD though...
I might end up buying another newer head unit.... decisions decisions...:-))
Old 12-20-2007, 03:43 PM
The GM9-AUX adapter will work with the cassette head unit. It works with all model years of cassette - only CD head units have the model year compatibility problem.
Old 12-20-2007, 06:38 PM
plopp's Avatar
Great.... I just received a tape deck that I got on Estink for $20 shipped.... missing a few ***** that I can transfer from my CD unit.... hope the HU works...I'll find out this weekend
Quick Reply: ipod question
