Will this amp have enough to power this sub properly?
Old 01-15-2008, 12:56 AM
joelx21's Avatar
Default Will this amp have enough to power this sub properly?
I forgot to mention, I'm going to use it on an MTX stealthbox
Here's the AMP http://www.bestbuy.com/site/olspage....=1134701297803
Product Features
Alpine products do not ship to Puerto Rico
Professional installation is strongly recommended for this product. Please visit your local Best Buy store for details.
600W peak output @ 4 ohms, bridged
400W RMS (continuous) x 1 @ 2 ohms, 14.4V, 20Hz - 20kHz, 1% THD
220W RMS (continuous) x 1 @ 4 ohms, 14.4V, 20Hz - 20kHz, 1% THD
MOSFET power supply delivers clean power with minimal heat dispersion
Bass Engine with Bass EQ
Adjustable 50-200Hz low-pass crossover
Continuously adjustable gain control
Subsonic filter
Thermal management processor for continuous bass performance without overheating
Discrete preamp stage; nonfading preamp output
Top-mounted blue LED power/status indicator
STAR circuitry
Gold-plated input connectors
Here's the Sub
http://cgi.ebay.com/ALPINE-SWR-1042D...QQcmdZViewItem
Subwoofer Specifications:
Subwoofer Size: 10"
Impedance: 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 1500 watts
RMS Power Handling: 500 watts
Woofer Surround: HAMR Rubber Surround
Woofer Composition: Kevlar Reinforced Pulp
Sealed Box Volume: 0.5 - 0.8 cubic ft.
Ported Box Volume: 0.6 - 1.3 cubic ft.
Sensitivity: 83 dB
Frequency Response: 26 - 600 Hz
Xmax (millimeters): 18.2
Top Mount Depth: 6-7/8"
Cutout Diameter: 9-1/8"
Warranty: 1-year SE
Old 01-15-2008, 04:15 AM
fredmr39's Avatar
Define "properly"... Is it enough? - yes... can you give it more? -yes..
Old 01-15-2008, 12:57 PM
Eskimo's Avatar
Yes, that's a good match.. wire both coils on the sub together, + to +, and - to - to make the amp see a 2ohm load.
That sub would be decent in a Kee Stelthbox...
Old 01-15-2008, 02:49 PM
joelx21's Avatar
Thanks for the responses... and I forgot to mention that I'm planning on using it with an MTX stealthbox.
If not this amp... do you guys have any other suggestions? I have the ideal amp that I would love to have, however, it's expensive as hell....
New ALPINE PDX-1.1000 Car Amplifier 1000w RMS Amp Mono
http://cgi.ebay.com/New-ALPINE-PDX-1...QQcmdZViewItem
SPECIFICATIONS
RMS Continuous Power (14.4V, 20-200Hz)
1000 Watts x 1 @ 4 Ohm
1000 Watts x 1 @ 2 Ohm
S/N Ratio : 110dBA
CEA2006 S/N Ratio : 80dBA
Input Impedance : 10k ohms
Frequency Response (200Hz/-3dB) : 20 - 200Hz
Input Sensitivity : 0.1 - 8.0V
Dimensions : 10-1/8" x 2-7/16" x 7-9/16" (WHD)
Old 01-15-2008, 09:03 PM
Eskimo's Avatar
I just bought a reman'd Kenwood mono amp for my truck , a KAC-9102D, for $131 shipped off pricegrabber - it does 500 at 4 ohm, 850 at 2 ohm, which is freakin plenty.
For the price, it can't be beat, though new, it retailed for almost $300. It's not the best or cleanest thing out there, but on a sub-only application, I'd bet you'll be hard-pressed to tell the difference, especially with a down-firing sub.
Since you're running the MTX box, save some money, you don't need a top-of-the-line amp... Kee has some decent deals on mono amps.
Old 01-15-2008, 09:25 PM
Gordon0652's Avatar
I am guessing that sub would be really happy with 400 watts rms in a ported box, and 750 watts rms in a sealed box! 1000 watts rms would be a little over board.
And since you have DVC 4 ohm, bring that baby down to a 2 ohm total load and you will be good.
IMO i would like to see the sub at a 2 ohm total load and hooked up to the Alpine MRP-M650 in a sealed box!
Old 01-15-2008, 11:53 PM
noriceinside's Avatar
+1 for factory refurbished amps. i just bought a kicker ZX700.5 amp. 1520 peak output...$197.50 shipped
Old 01-16-2008, 09:06 AM
Gordon0652's Avatar
See if you can sell the MTX stealthbox, and buy a Subthump stealthbox because the MTX box is spefically made for the MTX sub. They might have different mounting depths, and cut out diameters, and volume cu. ft.)
Old 01-16-2008, 10:37 AM
95bat's Avatar
The type R can handle a lot more than 500 watts as long as it is clean power. That is for people trying to get the absolute most from their system, though. The amp you picked will work fine.
Old 01-20-2008, 12:42 AM
Chattanooga's Avatar
THATS ON EBAY!!!
I got a 2 channel Brand new Kenwood 1000w amp for 100$
Sounds good as hell
Old 01-21-2008, 01:57 AM
95bat's Avatar
2 channel for a bass amp is not the smartest thing to do.
Old 01-21-2008, 08:29 AM
dragonrage's Avatar
Those people should be buying better subs than Type R.
Old 01-21-2008, 12:54 PM
shaun's Avatar
i had the EXACT set up and it sounded good. but i switched the sub with a memphis m1 and a mtx thunder 3401 thats also rated at 400 but on the birth sheet it put out 488 rms. the new set up sound's way better and plays a lot lower and deeper. the alpine can use more power than that amp puts out at least 500-600 watts. but with that set up it will sound good just not the best sound posible.
Old 01-21-2008, 11:36 PM
Gun5's Avatar
get one off ebay reman or new hell i justbought a used alpine 400 @ 4 and 600 @ 2 (plenty because alpines make very clean power usually and like most good companies are underrated so its really 450-500 and 700+)
$120 shipped to my door
Old 01-22-2008, 10:37 AM
95bat's Avatar
I'm not defending the R by any means, but people have put up 150+ with the R
Old 01-29-2008, 09:24 PM
stewaj11's Avatar
I know for my systems I always like to get an amp too big for the subwoofer, for the simple fact that I like to turn the gain down so the amp isnt working as hard..... But that amp will power and it is Alpine so it will hold up.
