2003 Subaru WRX vs 300C Hemi
Happened too fast for a camera as I wasn't expecting a race. I just bought the WRX and was breaking in the new clutch for 500 miles (was bout 450, so I said wth) and wasn't quite broke in yet, so I didn't powershift. We rolled up to a light beside each other.
He looks over and I grin and rev..so we roll out to about 10mph. I'm just waiting for his go. I was on top of it, as soon as he punched it, I hit full boost immediately and pulled maybe a fender on him. That was short lived as I short and granny shifted 2nd, and he started coming around me.
Speedlimit was 50, so by 60-65 he had a fender on me and I let out. My first race in the subie. I'm assuming he was "stockish" like me and didn't know what to expect, so I'm ok with the outcome. I only have a blowoff valve and fart can from the previous owner, which prolly do nothing for the performance. I need to do a few mods and get a tune. It backfired when I hit second, which means its running a bit rich, right?
Im new to these cars, but I got a good deal, and so far it seems like a heck of a car. It has 138k miles, but hasn't seemed to have lost much power. We could have raced again at the next light, but there was traffic, so I just let him go. I do plan on racing it some more and getting some track times this year..its different to take off without spinning..on street tires.
turbo's crap out: probably already been replaced since the persistent rumor is that you get between 40,000 and 70,000 miles of normal use out of one before it goes. Other than that, can't recall too much bad- unless you go for more boost, then the stock transmission are a weak point that is solved by inserting a Sti transmission which is effectively bulletproof.
Thought long and hard about getting a Sti before I got the GTO: then I found out that they dont get any better gas mileage so I said F* it, give the the LS2!
I will say, if you power shift and clutch dump every stop light, your syncros and gears are likely to fail.
I owned a wrx for 5 years before I bought my gto.
Nice race OP. Get rid of that bov and go stage 2. You'll love it.
Get a catless downpipe/up-pipe(stock has 3 cats between the both of them) if you don't half to worry about smog, 3" catback, and a Accessport, then later get a VF39 turbo(STI turbo) and a tune . All can be bought use for cheap and will make a huge difference in the power when compare to stock. I think stock WRX are putting out 185AWHP so those mods should bring you up considerably. You can add headers to if you want ! I got beat in my STI when I was stock by a full bolt-on wrx.
The BOV is making the car run rich a the stock should be fine or a STi would suffice, and get rid of the fart cann and get a catback like said above.
WRX weigh less than the sti cause the drivetrtain is not so beefed up ! Stay away from Exedy clutches, the don't last long at all.
Just go and have some fun ! You'll suprise the hell out of some people with these cars especially the old hot rod guys.
A friend had an 04 wrx with exactly those mods. At 53k miles the second gear sychro blew out. But god dam when the turbo kicked in it was ridiculous!
I've got about 2 grand to spend..where's a good place to round up some of these perf. mods on the cheap? The trans is in great shape right now and since I just installed a clutch, I think I'll press my luck for a while on that. What should I put down with the above mods? Where (rpm) do these cars make peak power stock? What should I expect in the 1/8th taking off @ low rpm?
Goto Nasioc.com ! Its an all Suby enthusiast site. $2k is good for plenty of mods, you should be able to get the whole turboback system, up pipe, Accesport(a handheld tuner with OTS maps on it that you download off of their site and then flash onto the cars ecu. Plus when you get tuned your maps will be on it) for probably around $1200. The Accessport will probably run you $350(on average, could be more)depending on what version you get(I or II). Its also year specific and mate to your car.
A TBE(Dp & Catback) & Accessport will allow you to go Stage 2, you just have to flash it on when you get the Accessport.
If your a really good driver you can crank out 1.6-1.8 60' ft and a 13.7-8 1/4(IDK what that translate to 1/8 but these cars are great for 1/8).
According to Cobbtuning.com stage 2 will get you to 285hp @ the crank thats up from 227hp and with some tuning you caould possibly get an additional 15-20+ but that turbo will be peaked. Full boost by 3000 or so.
Its been a couple of years since I owned my STi so the prices on stuff may
be higher or lower.
There's plenty of other sites so just go to google and type in WRX forums.
be higher or lower.
as someone else said get rid of that bov, the reason for it spitting flames is because the computer freaks out and dumps fuel. they come stock with a recirculated diverter valve which dumps air back into the hot side intercooler piping.
Diverter valve is a VW/Euro term.
The wrx/sti/LGT all come with a 100% recirculating BPV, stock. (ByP*** Valve)
Once you let off the throttle (under boost), the pressure recirculates back through the intake after the airflow sensor, to keep the turbo spinning and build boost for the next gear. If you have a BOV, the pressure vents out into the atmosphere. Making a cool swoooooosh sound I might add.
Having compressed air shoot back into your intercooler piping with spin or stall the turbo wheel. Which is the complete opposite reason why you have a BOV/BPV/Diverter valve/etc. in the first place.
Found out last night just how bad the car was running..may have video up soon. I left at 4500rpm at the local 1/8th and only managed a 9.5 powershifting at 6500rpm. It took off decent but not perfect..but the turbo civic I raced caught me at half track and put 2 cars on me.
Don't let your ego get the best of you. That's how **** breaks. . . . ask me how I know.
imo since the wrx is all wheel drive it ganna lose power from a dead stop cuz it got to transfer power to all 4 wheels. i owned a wrx for a while. now drive a huge truck to run all yall over j/k dont get offended
***Repost Police***
Gotta slip that clutch some more, cuz you're bogging as soon as you come off the line. And FWIW, my stock 150k+ mile '94 Integra ran a 9.7 . What was your trap?
