Street Racing & Kill Stories Basic Technical Questions & Advice
LS3 vette vs 03 bolt on and pullied termi and pulley and tuned e55
Old 10-11-2014, 11:13 AM
03_Z06's Avatar
Default LS3 vette vs 03 bolt on and pullied termi and pulley and tuned e55
I just got this vette a month or so ago finally was able to have some fun with it, the only on it is a vararam intake. I thought it would've done better than it did but I feel like the TM is killing it at WOT shifts.
Old 10-11-2014, 02:30 PM
HCI2000SS's Avatar
Seems about right to me considering the Termi has another 80 hp or so
Old 10-11-2014, 05:25 PM
Fahcue's Avatar
c6 got walked
Old 10-11-2014, 06:24 PM
Nick.H's Avatar
makes sense. beautiful C6 and beautiful cobra
Old 10-11-2014, 06:30 PM
OneSlowV's Avatar
Those E55s are really strong cars for just simple mods and the weight they carry.
Old 10-11-2014, 10:34 PM
2003Cobro's Avatar
Wow I almost bought a c6 GS instead of my cobra. Phew...
Nice run tho beautiful vette
Inb4 Hio I proper set up
Old 10-12-2014, 01:50 AM
Coupe4life's Avatar
+1..and my gosh how much that passenger weighs in that last run.
Old 10-12-2014, 04:33 AM
Arctic's Avatar
sorry i was taking a nap between everyones shifts, what was this video about again?
Old 10-12-2014, 05:24 AM
03_Z06's Avatar
Thanks man, and I just ordered some LTs and an X-pipe which will be here this week, we're going to run them again after those are on and I get a tune to see if I stand a chance that way.
He's a big guy, about 235 the cobra did jump me a bit on that run (not that it would've made a difference) and once he started i wasn't going to catch him
Old 10-12-2014, 06:38 AM
HioSSilver's Avatar
It's a stock vette dumbass.....vs a double pulley car.
Good run. Would've liked to seen runs w/o a passsenger.
Old 10-12-2014, 11:12 AM
2003Cobro's Avatar
He has a Varam intake. Must need a toooon for 100rwhp more. OP ask hio to show you where to start sawing your vette. He might have templates available.
Also larger upper with a lower will net same amount as just having a smaller upper. Plus anything over 12psi on a stock eaton is a waste. He made the same power i do upper only.
Old 10-12-2014, 01:26 PM
NW-99SS's Avatar
Good runs OP. Results as expected on an otherwise stock LS3 with a CAI.
Get that exhaust and tune on and go for a rematch without the passenger!
Old 10-12-2014, 01:37 PM
MikeWS6's Avatar
That Vette is probably at 390rwhp. Expected out come.
Old 10-12-2014, 02:25 PM
HioSSilver's Avatar
The more you type the more I know you don't have a clue about much of anything.
A varam intake ....big f- deal. Do you really think that compares to changing the atmosphere your engine runs at? A typical upper/lower will get you 14-16lb. My notch has a 2.93 upper and a 4lb lower.
Old 10-12-2014, 02:43 PM
2003Cobro's Avatar
Says the genious who blew up his termi swapped Fox.
Old 10-12-2014, 02:45 PM
HioSSilver's Avatar
i didn't blow it up. More of your mouth spewing **** you know nothing about.
Old 10-12-2014, 02:54 PM
2003Cobro's Avatar
Ok. Either way C6 according to the principles of Hio is improper. Needs mods, weight reduction, and a tune. This would be proper.
Old 10-12-2014, 05:58 PM
2003Cobro's Avatar
Here we go. Boost=cheating. Cubic inches, cutting holes in car, lightening drive train and valve train all good to go. The book of Hio verses: 55-57
Plus unless your ported your spinning your Eaton a little beyond its range. Good luck with 190 Degree IAT2s(you know what those are?)
Old 10-12-2014, 06:29 PM
03_Z06's Avatar
Couldn't we all use some more mods?
Old 10-12-2014, 06:42 PM
madmike9396's Avatar
Exactly what I was thinking. Shifting was SLLLOOWWW
Quick Reply: LS3 vette vs 03 bolt on and pullied termi and pulley and tuned e55
