Street Racing & Kill Stories Basic Technical Questions & Advice
A4 Street-racers inside please.....
Old 02-11-2006, 09:52 PM
TheDIZZ01's Avatar
Default A4 Street-racers inside please.....
First off, street-racing is bad and you shouldn't do it. But anyways...
What's your converter of choice (stall/str) and how hard can you leave with a prepped car and road?
Old 02-11-2006, 10:09 PM
sleeperstyle's Avatar
if you strictly street race, i'd say DON'T get the converter i have (2.5str) because it just hits to goddam hard for the street. i can almost never launch to the full potential of the car ont the street, but most other cars cannot either so it is all relative. i usually have to take it easy out of the hole to avoid wheel spin and then lay into it after about 10 feet.
don't go lower than 3500 stall (99% of people will tell you this) and pick a stall that will compliment your tires too. if you only plan on running street tires get a lower str, if you are rolling out on et streets a higher str might help you.
search, this topic has been beaten to death.
prepped road= a whole different ballgame too.
Old 02-11-2006, 10:15 PM
SMAX's Avatar
3.73'+ssf3500 2.5str+26x10.5 mt et streets @15psi=ok on the street
Old 02-11-2006, 10:21 PM
TheDIZZ01's Avatar
sleeperstyle, running 275-17" m/t drag radials w/ 390rwhp heads/cam (extremely small cam) w 3.23s......about to get a fuddle 3600/2.2str (power really starts to come on strong at 34-3500rpms, spins to 6400)....wondering if i should raise stall and/or drop the str
and yes, ill always be dropping the tire pressure and heating them up well, using VHT if ive got it
i have searched a lot, but when most people see/hear street racing mentioned, they think of stoplight battles on street tires, from roll etc. im trying to find some first-hand experience (and i know theres a lot of us out there that do it the same way).
Old 02-11-2006, 10:34 PM
djsanchez2's Avatar
Just starting to really mod my car, very interested in this topic. I've gone a few times and i've had nothing but sucess with the stock stall, but it is time to step up and race some more heavily modded (h/c, nitrous domestics and more fully built turbo imports) cars.
Old 02-11-2006, 10:40 PM
Formula_X's Avatar
Default re:
I have considered a stall b/c im interested in making my car faster, but I don't have alot of $$ at the time. I have asked and started threads about this question, but I have never really understood.... when driving regularly (not racing at all), when you give the throttle to go, does the car have to rev to 3500rpms before it moves... if so, wouldn't you burn out even when you don't want to?? ?? Also, how much is a 3500 stall and how much is installation cost roughly?
Old 02-11-2006, 10:43 PM
Formula_X's Avatar
I also want to make a request... If anyone has a video or can make a video inside of the car of them driving regularly with a 3500 stall, can you please, please, please post?
Old 02-11-2006, 10:44 PM
1 BLOWN V8's Avatar
I didn't listen to everyone and to be honest I am glad I didn't.
I went with a TCI 3,200 stall with a 2.2 STR with a set of 315/35/17 Nitto drag tires and I cut a 1.6 to 1.7 all the time plus the car just hooks and drives awesome.
I also have 342 gears.
Old 02-11-2006, 10:48 PM
that fuddle is probably fine, and good choice on the tires also they do hook . you might think that stall is too low of an rpm if you race the car alot, but you'll only realize this after having it for a couple months. if you just drive it around alot then it's probably a good rpm. hell, if i had the $ for a 12 bolt with 3.73's i'd be running a 4200 2.5str converter right now, but it'll be hell driving around with the 2.73's so im content with what i have. i actually upgraded from 3500 to 3800 after about a month so it isn't uncommon to try one and if you want more/less swap it out.
the stall just means that you have to give the car more gas (like 50% throttle instead of 20% throttle) to accelerate at the normal rate of traffic. the rpms will just "sit" higher when normally driving till it locks up, then it is the same as stock. it won't be as punchy normally driving, and will feel slower around town and whipping through traffic. once you go wot though, you'll understand why you bought it.
and like above, some people will swear by the lower stall. it is all in what you like and what you do with the car.
Old 02-11-2006, 10:52 PM
Pimpium57's Avatar
What was everyone telling you to get?
Old 02-11-2006, 10:56 PM
Pimpium57's Avatar
My old setup, MTI C1 hammer cam, Yank ST 3500 (2.5str), on 17" Nittos cut a 1.66 60' and did 7.68 in the 1/8th.....this is all thru stock manifolds and Y too.
However, on the street, there was abolutely no way I could even come close to that kinda launch, no matter what the prep I tried to the car AND road.
Those tires, with the slightly softer hit from the 2.2str, should work out a little better than my setup.
Old 02-11-2006, 11:05 PM
1 BLOWN V8's Avatar
3,600 to 3,800 or I would regret it if I didn't. But I am glad I went with the 3,200 with the 2.2 str.
TheDIZZ01's Avatar
In the end....I don't care how the 'verter drives. I'm looking for the converter that's going to get me down a 1/4mi stretch on a prepped road.
Old 02-11-2006, 11:07 PM
TheDIZZ01's Avatar
Can you get a good street launch on this setup?
Old 02-11-2006, 11:10 PM
1 BLOWN V8's Avatar
Very good launch on 30psi also. Also from a roll 20-30 MPH if I hammer it it hooks hard. Of course if I want to show boat I can smoke the heck out of them on demand.
Old 02-11-2006, 11:16 PM
TheDIZZ01's Avatar
Good to hear.......I get a lot of press to go for a 4k stall with a 2.0 (or even lower) str. However, I'm not only worried about traction/launching, I want to make use of the powerband I've got.....so shift extention comes into play too. Choices, choices, I shoulda stayed with my M6 w/ 4.10s!
Although I don't mind about the drive quality, that might be an overkill of looseness. I'm willing to bet my 275 MTs will out-hook the 315 Nittos too, so I might have even better luck.
Old 02-12-2006, 12:00 AM
CuNfUzEd's Avatar
Keep your manhood! Go T56!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-12-2006, 12:02 AM
Pimpium57's Avatar
Old 02-12-2006, 12:50 AM
Formula_X's Avatar
Probably not a good idea for me to get one then, because my car is a daily driver and I rarely got WOT. And I really don't street race often. So, the stall would just make my car feel slower and would be more of a pain than anything.
Old 02-12-2006, 02:12 AM
Dragframe's Avatar
a stall has the main purpose of making your car a animal off the line.... if you dont are about racing... then why even consider it?? Why make your car faster if you dont race??? Totaly redundant...
oh.. and my buddy has a stall on his 68 truck... 3200.... feels just like driving my car (stock)... so yes a stall is very streetable...
