Lowered!!! Now how to get rid of the ricer look out front?
Old 10-11-2008, 07:42 PM
99wssixm6's Avatar
Default Lowered!!! Now how to get rid of the ricer look out front?
I have had my WS6 lowered for more than a year now and I'm trying to figure out how to remove that slammed Honda look the front wheels give. I purchased Strano Re-valves, Eibach pro-kit(the ones that lower the least, sorry sam you didnt have your springs out yet) from Sam. I love the handling and stance but just cannot stand how the front tires sit inwards on the top......alot of negative camber. I think a adjustable upper control arm will fix it but I'm not sure. Have any of yo'all fixed this or found a way to correct it.
I would appreciate a answer and Sam if you have anything for me I will buy from you and only you.
Thank you
Old 10-11-2008, 07:47 PM
Jefro6996's Avatar
Did you get your car aligned back to stock specs after you lowered it?
Old 10-11-2008, 07:51 PM
02Z28LS1's Avatar
first of all, if you're talking about the tops of the tires being farther inward than the bottom, that's not caster, that's camber.
any alignment shop that's any good should be able to correct the camber fairly easily. although, if the drop is big enough, there may not be enough adjustment with the stock parts, so in those cases, adjustable front control arms may be required to get enough adjustability to bring them back to spec.
Old 10-12-2008, 09:16 AM
spaz1's Avatar
Mine looked awesome when it was lowered. I think It is an optical illusion, what style and size wheels are on the car? The top of the wheel well is quite wide. My wheels have a lower offset so the stuck out more than stock. I never had to adjust camber or caster only the toe. -1.0* camber +4to +5 caster and 0* of toe.
Old 10-12-2008, 07:03 PM
Viper's Avatar
Most people lower their cars to get more camber so it will turn in quicker in the corners. FWIW.
Old 10-14-2008, 06:21 AM
Cap'n Pete's Avatar
You think that -1.0° of camber is an optical illusion???
If 99wssixm6 had his car lowered, and never had it aligned, he could have some pretty good negative camber, and it WILL make the front wheels look tipped in at the top, esp. in comparison to the back wheels (~1° is visible to the naked eye ).
I have my car setup with about -2.5° of camber in the front, but I WANTED that much camber!! Yes, it's QUITE noticable, but I don't care ... the car performs awesome on the track (and in auto-x) which is what I was going for, and it takes corners on the street quite nicely too .
The stock spec is something like 0.4° of positive camber, so that the tires follow the crown of the road while driving in a straight line. Doesn't do much for the tires around corners though .
99wssixm6, have your car aligned, and get them to set the camber to about -0.5° on both sides. Max out the caster (positive) and somewhere around ~0 toe, or slightly toed-in (for high speed stability). If you put suspension into your car, you might as well get SOME of the benefits of it .
Old 10-14-2008, 07:14 AM
HoLLo's Avatar
My old Sportline springs had that negative camber to it, looked retarded. I took it to a shop to have them align it as much as possible, it got better but never 100% better. I just went back to WS6 springs
Old 10-14-2008, 12:29 PM
LS1TECH Sponsor
Sam Strano's Avatar
Originally Posted by 99wssixm6
I have had my WS6 lowered for more than a year now and I'm trying to figure out how to remove that slammed Honda look the front wheels give. I purchased Strano Re-valves, Eibach pro-kit(the ones that lower the least, sorry sam you didnt have your springs out yet) from Sam. I love the handling and stance but just cannot stand how the front tires sit inwards on the top......alot of negative caster. I think a adjustable upper control arm will fix it but I'm not sure. Have any of yo'all fixed this or found a way to correct it.
Thank you
In fact we do have something to help. We make offset upper control arm bushings. We started them to gain negative camber for racing, but simply by installing them differently they can be used to equal effect to reduce negative camber for those that have too much for street use.
They are $159 a set, replace the upper control arm bushings and should allow you to get rid of about .5 degrees of camber. Not a ton of change, but in my experience with these cars and the amount of camber you get on a lowered one, they will get the alignment back to, or at least a lot closer to stock specs.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-14-2008, 04:55 PM
spaz1's Avatar
I don't think 1* -ve camber is an optical illusion. I said my car on the pro kit didn't look like the wheel was in that much at the top. My wheels stuck out alomst flush with the fender lip less positive offset than the stockers. Depending on what wheels he was using it may look bad at -1* while others don't look that bad. I would say -2.5 is way too much for the street. But that is just my opinion.
click pic for bigger
Old 10-15-2008, 08:15 AM
Cap'n Pete's Avatar
For a purely street driven car, absolutely ... I wouldn't have run this much. But I take my car to the track a fair bit, and I don't drive it to work 5 days a week, so I was willing to sacrifice a little bit of excess tire wear for improved handling ..... and it works well .
Old 10-17-2008, 10:08 PM
99wssixm6's Avatar
Thanks for the replies. I have corrected the Camber/Caster error. Sorry I guess a few too many beers when I typed it. Anyways, I did have the alignment done, actually I'm a Service Manager at a Dodge Chrysler Jeep dealer and had our lead suspension guy do it. He used to work for Hunter Engineering (made alignment machines) and a BMW race team. I guess he isnt used to the F-body. I'm sorry to ask this but how do I "we" adjust the Camber on these cars....is there any top mount adjustment.
Thank you
I think I'm gonna go with Sams bushings.
Old 10-17-2008, 10:49 PM
Foxxtron's Avatar
There is no access for any adjustments to be done with the factory upper control arms (except installing offset bushings like Sam's, which is a "static" modification).
It's all done strictly from the bottom where the control arms mount on the K-member. The Hunter machines usually had a guide on them for how to adjust them. They list a "special tool" used, which I advise to get in order to make the job significantly easier, however it can be done without (just will be much more labour without them).
On each front lower control arm are bolts that mount the control arms to their respective slots in the k-member. The front bolt on each arm are for the "camber bushing" and the rear bolt on each are for the "caster bushings." Bear in mind that these bushings have lots of loads applied to them (especially the caster bushing). Since the last 4th Gen F-body was produced in 2002, those bushings listed you know may be severely worn, which you know will cause more frustration with adjustment and retention of alignment settings.
You may want to source these bushings just in case (rubber is recommended, poly is NOT).
Quick Reply: Lowered!!! Now how to get rid of the ricer look out front?
