which shocks would you recommend?
well my stock shocks are gettin old and started squeaking recently so i decided to get new shocks. i was thinking about getting the bilstein heavy duty shocks from http://www.lingenfelter.com/store/be5-2406.html... what do you guys think about these? if you don't recommend these or have had problems with these or recommend any other brand of shocks.. i drive the car to school most days when the weather's nice.. thanks in advance
i just ordered some strano spec bilstein hds, and they work really well. i got them because i dont plan on lowering my car. if i planned on lowering i would have gotten the konis. the strano spec set that i bought uses a different valving for the rear shocks. its just an older versioin of the bilstein hds that have are set up a little better than the new ones. good luck
if you do a search you'll find all kinds of opinions on this issue. especially in the KYB vs Koni department. it all depends on your application. i put on some KYB and i don't have any complaints, they're good for a stock replacement/DD, but i wouldn't push them past that. good luck with whatever you choose.
LS1TECH Sponsor
Well, a set of Bilstein's the way I sell them (using a better IMO rear valving) is $425.00 for all 4. I sell those fronts for $110 each vs. Lingenfelters $139, and use a better rear damper (more rebound, less compression, still a fully covered Bilstein HD for warranty still).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
FWIW, that statement is coming from someone who now has a second set. I seem to recall the car and shocks met an untimely end in a hurricane..... Given the choice to replace with something else, Adam didn't.
__________________
On a car lowered ~1" would they benefit from a lowered bottom shock mount?
LS1TECH Sponsor
Yes, I sell just rears. They are $85 each. Moving the shock mount is a useless, time wasting endeavor. The shock have way more compression travel than we can use, and shortening them or lowering the mount only costs you droop travel.
__________________
LS1TECH Sponsor
No.. There is a difference between Revalves and my selling an alternate valving I know about, but others don't (or don't seem to care about). The Strano spec HD's are production HD fronts like everyone has, but with an older and better rear valving.
__________________
LS1TECH Sponsor
I mis-typed earlier, was working off memory of old pricing.... Sorry.
Fronts are $135 each, rears $87.50 each. Totals $445. If you buy the as a set, they are $425, saving $20.
Sorry for the confusion. Hard to keep up with all the numbers in my head.
__________________
