I don't have an adjustable and put on wider wheels and tires. The car pulls a little to the right. The rear sits a little to the left but no rubbing issues. You think this could be my pulling issue?
Did you lower the car and install the wider tires at the same time?
Did the pull start after the tires were put on? I would suggest a front end alignment first and see what happens there... that is most likely the cause.
