whats the best line lock
Old 02-09-2009, 06:38 PM
jp98's Avatar
Default whats the best line lock
Who makes the best line lock? Is the slp line lock kit a good one, in the picture they show on slp.com it looks like the line lock has a toggle switch not a push button? Anyone using the slp line lock?
Old 02-09-2009, 06:44 PM
'00 formula elesone's Avatar
I have the slp one. went in real easy. works great!!!!big plus esp for m6. I went with lighted rocker switch. yes it did come with toggle
Old 02-09-2009, 07:29 PM
tillery's Avatar
Get the one from SJM. Its more track legal and safer for the street. I got the SLP one and its overpriced for what you get. The install is easy but instructions sux.
Old 02-09-2009, 08:22 PM
SS SLP2's Avatar
used SLP'S unit
Ithink if you gravity bleed the line as I, will save you time and problems
I have no air problems ,press brake, set switch and you will not move a inch
come see them smoke
http://kickme.to/jgruggles
LINE LOCK INFO
IS hole behind pcm , but i drill hole beside steering colum also ( drill from inside out ) put a peace of rubber hose in hole ran wire inside hose, then use same type wire wrap as GM,tie wrap to the big rubber hose comming over master cyl
I also mounted switch in ash tray
using last 7 years
my .02
PS ::Connect brake line to master cyl and line lock ,the second line which goes to ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMBER BRAKE FLUID WILL RENOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind
also the picture from SLP is UPSIDE DOWN install with the wire connection UP
Sorry for the long post, hope it helps
Johnny
Old 02-10-2009, 02:43 AM
35th SS's Avatar
hurst L/L on both cars.no problem here.bent my own lines from master to the unit.
Old 02-10-2009, 05:36 AM
Big Bird WS6's Avatar
slp. and haveinstalled 100 plus kits. love the ****
Old 02-10-2009, 03:19 PM
BMR Tech's Avatar
SJM Manufacturing hands down best kit on the market.....great product tech support
Old 02-10-2009, 03:26 PM
SuperSlow02's Avatar
SJM here also...works perfect, get the top mount unit, super easy to install..I went with the stealth and well its still obvious you have one and a lil hard to drill the holes with a basic drill..
Old 02-10-2009, 03:31 PM
mcamarols1's Avatar
bought a SLP and changed over to SJM....more happy with SJM
Old 02-10-2009, 05:47 PM
SJM Manufacturing Inc's Avatar
Thanks for the recognition guys!
Our kits are complete. We offer a choice in solenoids as well as line configuration. Our wiring kit is engineered well with saftey features. Each kit comes with two switches and remote mount LED indicator (one switch is a master power switch; the other is the control momentary switch). Other misc. electrical connections are included.
All lines are pre-formed. Every fitting which uses thread sealant is preassembled; Teflon tape etc is not needed. We even include a grommet for the firewall.
Kits are always in stock typically shipping within 24 business hours.
Old 02-10-2009, 05:55 PM
SJM,
what makes yours different form slp.
and superslow. what is the stealth kit? or sjm on that one?
Old 02-10-2009, 06:06 PM
Originally Posted by Big Bird WS6
SJM,
1) Our kits are wired with superior circuitry design.
2) They are safer, accidental deployment cannot occur...leading to longer expectancy life of solenoid.
3) You know when our circuit is live due to the remote mount LED feedback.
4) Our kits are track legal.
5) There is no assembly or need of thread sealant on the fittings.
6) Kits are complete kit without having the need to re-purchase additional components.
7) Our customer support, in my opinion, is superior (biased opinion of course)
Superslow is referring to our two line configured kits. One is slightly easier to install due to solenoid location (top mount). The other kit has a stealth appearance since the solenoid is more hidden. We've produced these for the F-body years before SLP decided to sell them. Apparently they liked our front mount line configuration. Location and line configuration is where the similarity ends.
Old 02-10-2009, 06:44 PM
Hardtop's Avatar
SJM. Their line lock has been on both of my Z/28's. It's a quality product and Steve has great customer service.
Bruce
Old 02-10-2009, 07:09 PM
4WOFURY's Avatar
SJM,
What is the difference between Line Lock kit (P# SJM-2B001X) and Hurst-Style Line Lock kit (P# SJM-2HX001)
Thanks
Old 02-10-2009, 07:33 PM
Spd-Kilz's Avatar
SJM here. Fantastic product and amazing customer service. Couldn't be happier.
Old 02-10-2009, 07:40 PM
*98TransAm*'s Avatar
SJM kit works great, your tires will be bald in no time
Old 02-10-2009, 08:10 PM
Originally Posted by 4WOFURY
SJM,
Thanks
The solenoid used.
Old 02-10-2009, 08:13 PM
03 BUSA's Avatar
SJM here as well. Never considered anyone else.
Old 02-10-2009, 09:27 PM
jp98's Avatar
Does the SJM kit come with the quick release button you put on the shifter? Or do you have to buy it separate?
Old 02-10-2009, 09:39 PM
Randy WS6's Avatar
I use the Hurst line lock
Quick Reply: whats the best line lock
