Sway bars... Hotchkis, Strano, Spohn, BMR, other?
Old 04-29-2009, 09:22 PM
flymybird's Avatar
Default Sway bars... Hotchkis, Strano, Spohn, BMR, other?
I've spent several hours researching here and different other forums which sway bars I should get after the shock of my Konis has subsided a little .
Due to the recent surge in sales (BMR, Spohn) the sway bar prices have gotten more to where I'm more comfortable with them than before. I thought for sure I was going to get Sam's sway bars because the difference in price between his and others was not that great and because of all the wonderful things I've read about them, etc. But, the prices on Spohn and BMR sway bar sets are quite a bit lower right now and I started wondering whether for the increase in price for Stranos I will be able to fully utilize those bars.
Current prices that I am comparing for a set of front and back are
Hotchkis - way above what I would consider ($500+?)
Stranos - $439 plus shipping (maybe $25, just a wild guess) = $454
Spohn - $296 with free shipping
BMR - $266 with free shipping
So, the difference in price is roughly in the range of $200 between hi and lo. That's a pretty considerable chunk of change. Before I was set on going with Sam's sway bars but because money is always in consideration, I'm now considering Spohn.
I don't race, so this is purely for my own street, every day driving entertainment. Will I be able to feel the benefit that the premium costing sway bars will give me? What do you think?
Thanks!
Old 04-29-2009, 09:44 PM
99Bluz28's Avatar
I would try sticking to a hollow sway-bar, which have the advantage of adding a minimal amount of weight, and sometimes actually reducing weight, over factory bars!
The only possible down side to a hollow bar is cost, if that's a factor for you.
IMO, take a good hard look at the Strano bars!
Old 04-29-2009, 09:46 PM
ZMONSTER!'s Avatar
I say no bar at all up front...but if you must. I used to run the complete strano setup. If I ever want to handle again, Ill save up for another set. No question in my mind strano or bust.
Old 04-30-2009, 06:58 AM
UMI Sales's Avatar
Thumbs up Sway Bar Question!
Hello
When it comes to sway bars. I would recommend Strano Bars. They are worth the wait!
Thanks
Brad
Old 04-30-2009, 07:38 AM
flymybird's Avatar
Originally Posted by UMI Sales
Hello
Thanks
Brad
Yeah after another several hours spent online reading all i could find on the topic yesterday that's also the unfortunate conclusion I've come to. (Unfortunate in terms of having to spend so much money, that is.) If only I could test drive different setups and decide for myself...
Old 04-30-2009, 07:45 AM
teke184's Avatar
i was amazed at how the handling of the car changed with stock suspension...but upgrading to the BMR bars.
for a $200 difference, on the street...i dont think you'd notice enough difference to warrent the price.
Old 04-30-2009, 10:32 AM
Major_Lee_Slow's Avatar
Before you decide what bar to buy you need to at least know what are your handling goals and what else do you plan on changing in the suspension. Then when you know your goals, you need to know the bar's Outer Diameter and Inner Diameter, or if it's solid.
Personally before I change any springs or bars on my car I sat down and formulated a plan for my car and identified the deficiencies I wanted to correct. I then reverse engineered the existing suspension to get a good understanding of the roll centers, camber curves, etc. Then I was able to plug in different bar and spring rates until the model delivered the results I desired. After that I went and bought springs and bars. The I drove it that way for a few years and re-asses my set-up and made more changes to reach my goal.
But that's me, I need to know if I am indeed making an improvement and not just think I did because of the placebo affect of thinking I made an improvement cause I spent alot of money.
Old 04-30-2009, 10:38 AM
driftpin's Avatar
I just installed a Spohn swaybar in place of a Suspension Techniques and the difference is like night and day. Not that that the ST was made poorly, it wasn't but the Spohn is incredibley well built, although it is meant for drag racing, I would suggest it to anyone. Spohn has great products. Strano and BMR are also good. If your not worried about racing at all you could get a ST, heck, I'll sell you mine, it only has about 50 miles on it.
Old 04-30-2009, 10:57 AM
flymybird's Avatar
I am all for that actually. However, I just don't have the background or the time to do such an analysis, and there aren't that many products out there afterall. So, I am hoping by reading other people's opinions I will be able to form my opinion.
I will never take this car to a race track. Any kind. I drive it on average 10 miles daily between work and home and some errands. From what I have learned, shocks, sway bars, then springs, make the biggest bang for the buck difference. I bought the Koni shocks from Sam (which might have been overkill, I will never know), but every time I take a spirited drive I grin like an idiot because of the stability that I feel with these shocks on that I never felt before.
The only reason I started this thread as I said before, was due to the large price difference that before was not present in my decision making. I understand the car is a money pit but in reality, if I didn't have to spend so much money on the sway bars I could get Sam's springs sooner, that's all.
It seems that no one is 'unhappy' with any sway bar they get but I have yet to read someone's unbiased reviews of the car after they have tried many different brands and types for street driving (of course, Sam has done that but he has "somewhat" stricter demands)
/rambling
Old 04-30-2009, 11:32 AM
Well at least determine the OD and the ID of the bar's you are considering. The stiffness of the bar is a cubic function of OD so 1mm makes a big difference.
The price differential you are seeing is not only a factor of build quality, but also specification. solid bars tend to be much more cost effective than hollow bars, but solid bars weight significantly more than solid bars.
Also, you want to properly match the bars to your springs. You mentioned you have Koni's, what springs do you have?
Old 04-30-2009, 12:06 PM
flymybird's Avatar
Right now I have the stock springs, but I will be going with Strano springs after the sway bars are in.
Old 04-30-2009, 01:37 PM
LilJayV10's Avatar
LS1Tech 10 Year
If you are going with his springs I would say stick with his bars. He can explain why he made the springs/sway bars the way he did. I would tend to think they would be better "matched" for each other.
Just my .02
Old 04-30-2009, 02:40 PM
dragonrage's Avatar
People, stop recommending this left and right. It might help you a tiny bit at the drag strip, but it majorly compromises handling and makes the car a lot crappier to drive on REAL roads.
My drive to work in traffic is more fun than going to a track and going straight.
Old 04-30-2009, 02:45 PM
flymybird's Avatar
lol. I kind of glanced over that one. Let's see... I'm trying to decide between a 32mm solid or 35mm hollow front sway bar... yeah, let me just get rid of one completely because typically doing the opposite of what makes sense works well, right?
Old 04-30-2009, 02:51 PM
dragonrage's Avatar
You could go half-way and do 35mm hollow up front, 21mm solid in the rear. The 21mm GM bars are cheap.
Old 04-30-2009, 03:35 PM
Daez's Avatar
Most people on here go for drag performance, removing the front sway bar helps alittle for that. I personally wouldn't do it, because I like my car to handle well, and I only don't go to the strip much.
Old 04-30-2009, 03:59 PM
flymybird's Avatar
Yeah I couldn't care less about going in a straight line... Give me corners! I will go out of my way to find the route that has curves even if it's a little longer than the straight path. I luuuuv curves
Old 04-30-2009, 04:09 PM
vjo90rs8's Avatar
Suspension Techniques 35mm solid bar up front, cheapest and heaviest bar per millimeter but I love it. I also picked up a 21mm solid rear bar off a thirdgen for $15, cleaned it up and sprayed it with some black paint and it looks great. Balance is near perfect with the rest of my suspension components.
Old 04-30-2009, 04:13 PM
flymybird's Avatar
Have you had any other bars than stock to compare to?
Old 04-30-2009, 04:17 PM
teke184's Avatar
curious where exactly in "upstate ny" you're from?
was born and raised just outside syracuse
Quick Reply: Sway bars... Hotchkis, Strano, Spohn, BMR, other?
