ABS INOP light is on after dyno????
Old 09-20-2009, 08:32 PM
bongva's Avatar
Default ABS INOP light is on after dyno????
Ok, so as I was dynoing my car last week, my ABS INOP light came on, I have double checked my abs sensors in the front, and the abs unit in the engine bay. Everything is fine, but the light has not gone away.
Before the dyno, everything was fine, and the light never came on before, but as i started my first pass on the dyno it was on. I was hoping it would go away afterwards but it didnt.
What should i check? and what could possibly be wrong?
Old 09-20-2009, 10:43 PM
bongva's Avatar
bump need help
Old 09-21-2009, 02:41 AM
1sicws6's Avatar
check above the rear end see if anything is unplugged, it can happen when they strap your car down...
Old 09-21-2009, 08:22 AM
Danny2tek's Avatar
Old 09-21-2009, 11:44 AM
bongva's Avatar
i have checked already, and nothing is unplugged...
anything to check specifically?
Old 09-21-2009, 11:54 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
It comes on during many dyno runs. The front wheel speed and rear wheel are too far apart for it to work correctly, so it shuts down the ABS and turns the light on. It should correct itself shortly
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 09-21-2009, 01:05 PM
bongva's Avatar
It has been a week.
Old 09-21-2009, 01:07 PM
bongva's Avatar
I found on plug on the top of th rear end, and three plugs that go into the chassis from the rear, all three are plugged in....
Old 09-21-2009, 01:47 PM
Have you changed front or rear wheel or tire setups? Gear setups? Anything else?
__________________
Old 09-21-2009, 04:10 PM
bongva's Avatar
i went from stock 16s 245/50, to ss wheels on 275/40, but that was about a month before the dyno.
and no they are not staggered. same tires and rims all the way around
Old 09-24-2009, 11:32 AM
bongva's Avatar
bump please looking for help
Quick Reply: ABS INOP light is on after dyno????
