Duralast and Moog tie rods the same?
I've read before that some Moog products are sold under other brands at a much cheaper price. Apparently they're all made by Federal Mogul or something like that. Anyway, I'm looking to replace my tie rod ends and I'd much rather pay $17.99 vs $50.99.
What do you think?
http://www.autozone.com/autozone/cat...questid=731019
http://shop.advanceautoparts.com/web...S_715235642___
What do you think?
yeah i'd go with the moog stuff. I paid a little bit higher prices for my stuff but since i also got an alignment and the total was only $300 ($320 w/ a $20 off coupon for any work over $200) i figure it's like i paid the higher prices but got the parts installed for almost nothing. IIRC had i gone to advance and bought inner and outer TRE's it would have been $235 before tax. so it's like i only paid $60 for the instal and alignment.
The Baer tire rod ends are a combination of heim ends and an adjustable "pedestal mount" that is attached to the spindle in place of the outer tie rod end. The "pedestal" allows you to adjust the mounting height of the heim up and down, so you can get the tie rod to more closely follow the arc of the lower control arm. This, in turn, allows you to minimize bump steer, especially on lowered cars.
well a new moog is like say 45 each. and i can get a set of the poly parts for like 20 for a set. that is alot cheaper. and the poly will last probly the life of your car
Moog joints meet or exceed OEM in terms of quality, and still use poly boots to seal out dirt.
The moog part is the entire tie-rod. The Energy supension poly boot is, well, just the boot. Do you need to replace the tie rod because it's worn or are you replacing it because the boots torn?
i am sorry my moog that i bought last year are great. i was just posing an option for the OP. then i was asking about the poly parts as a replace ment.
i dont need tie rods. just trying to throw outher options out there then just replacing the whole piece.
now if my moog boot tears i will probly run the poly part.
