alignments after lowering?
Old 01-01-2010, 01:47 PM
jutt26's Avatar
Default alignments after lowering?
I am currently researching lowering my 00 SS.
I have decided to go with Strano Springs and Koni 4/4s.
During my research, I have run across a couple articles that mention once a car is lowered, the geometry of the suspension changes and additional parts are needed to 'properly' align the car. I believe in both cases an adj. panhard bar was the solution.
Anyone run across this after lowering the car?
Old 01-01-2010, 07:59 PM
Foxxtron's Avatar
Absolutely. If you're ever thinking on lowering and what to do it "right", those are one of the imperative procedures.
Old 01-01-2010, 08:09 PM
99zee's Avatar
Once lowered you can tell how much the rear axle is off center. An adjustable PHB will re-center the rear.
Old 01-01-2010, 10:10 PM
DriftR's Avatar
An adjustable Panhard bar to center the rearend, and a front end alignment to fix the camber.
Old 01-03-2010, 02:08 PM
tillery's Avatar
Are you asking about the front end? Some people can get the front back to factory specs. I got some off set bushings from Strano to help with Alignment. Some people elongate the holes for more adjustment. And lowering the vehicle does make the Factory sway bars work harder. It is recomended to upgrade to a slightly bigger bar front and rear. But it all depends on driving style. With the SA Konis you may be able to balance the car to your style with small adjustments.
Old 01-03-2010, 02:21 PM
jutt26's Avatar
sorry, was referring to the rear end. Are adjustable LCAs required too?
Old 01-03-2010, 04:41 PM
35th SS's Avatar
yes if your moving the rear front to back.
Old 01-03-2010, 07:36 PM
therealcreeper's Avatar
you won't need them due to lowering, but they are a good upgrade. i would recommend lca relocation brackets though, to correct the angle after lowering.
my relocation brackets actually pushed my rear back a few inches, so i used the adjustable lca's to correct that. others have had the same problem as well. apparently it's an installation error of the brackets which causes it, but shortening the lca seemed easier.
Old 01-03-2010, 10:38 PM
JamRWS6's Avatar
Your issues will be in the front. Getting back to a stock caster/camber setting will be work and not likely uneless you can find someone who knows exactly what they are doing...even at that it still may not be possible to get back to stock specs.
I only say this meaning if you are concerned w/ tire wear. If you aren't, then dial in a degree of negative camber and have fun w/ how the car handles. Your fronts will get eaten up though.
Old 01-03-2010, 10:43 PM
this is what i did. no regrets.
Old 01-04-2010, 07:36 AM
teke184's Avatar
what part of the wheel gets worn down with this?
and what can be done to correct it?
Old 01-04-2010, 07:46 AM
pjb
pjb's Avatar
I hope nothing on the wheel is getting worn down.
Old 01-04-2010, 10:08 AM
with negative camber, the inside of the tire will wear faster. with aggressive street driving and some autox, the outside edges of mine get pretty chewed up too so it ends up balancing out for me.
Old 01-13-2010, 09:50 PM
BCKNBLK's Avatar
ask the person who aligns up the front of the car if the rear is off.... everyone goes on about adjustable panhard bar but only like 2% of everyone who lowered there car runs them......when i lowered the 87 iroc i ran springs and the rear was in perfect alignment with the stock bar still.
get springs new shocks and a 4 wheel alignment.
Old 01-14-2010, 06:35 AM
toadzq8's Avatar
You will need to corrrect the tie rod center line for bump steer, Sphon suspension has a kit for this.
Old 01-16-2010, 03:04 PM
rabbit320's Avatar
the bump steer kit keeps the car from 'bouncing/shuddering' hard around corners yes?
Old 01-17-2010, 11:42 AM
Squirts11's Avatar
After installing the Eibach Prokit, my rearend was off-centered. Just ordered the adj panhard bar to get the alignment corrected. Also ordered LCA's and relocation brackets.
Old 01-17-2010, 12:10 PM
kc533's Avatar
To the OP....I'm running the same setup up as yourself and my rear did need a slight adjustment of the panhard bar to get centered. It's very simple to adjust and can be done in your driveway.
Old 01-24-2010, 09:58 PM
stepuptata's Avatar
i have lowered 6 fibodies and never had to go with an adjustable PHB
Old 01-27-2010, 10:53 AM
JamRWS6's Avatar
And the rearend is probably not centered correctly on all 6 of them. It's OK, most don't fix that..I personally want it centered.
It is kind of like the difference between a good paint job and taking it to Maco. Maco is just going to tape it off and spray the car and it will look like crap w/ overspray everywhere and an obvious lack of attention to detail. That versus taking it to a shop that knows what they're doing and properly removes panels/moldings/door handles etc. to paint them and you end up with a product that looks right.
My 3 cents.
Quick Reply: alignments after lowering?
