sjm line lock how to seal
Old 04-18-2010, 08:27 PM
daniel6718's Avatar
Default sjm line lock how to seal
i got one of their line locks and mounted the ll right below the master...pp valve beside it...everythings good except the line lock has nothing inside to seal the line with? i have a double flaring tool...and fittings to fit it but you can tighten the fitting and the line is still loose there nothing for it to bottom out on??? anyone help me out?
Old 04-18-2010, 08:48 PM
SS SLP2's Avatar
new/used ?
Johnny
Old 04-18-2010, 09:09 PM
johnpate01's Avatar
I used a combination fitting for another project that you might be able to use for this. It was a 5/16"-24 (or whatever) male thread and used a copper crush washer to seal on one end, the other end was a 1/8" female brake flare. I got mine locally at a Royal Brass dealer, but Napa should be able to get you one.
Old 04-18-2010, 10:11 PM
daniel6718's Avatar
new
im not understanding how it sealed johnpate01? pics
Old 04-18-2010, 10:22 PM
johnpate01's Avatar
http://www.valleyhydraulic.com/flare-inverted.gif
In the picture, the left side is NPT (pipe thread), you are probably going to want one that uses a copper banjo washer. You will have to check the thread type. You screw the brake line into the right side in the pic. On the left side of the pic, you install a copper washer, then install the fitting into the lock. It's really simple if I had a picture available. I hope that I am describing it simply enough.
http://www.stangnet.com/images/stori...IM9825_800.jpg
Here is what the copper washer looks like.
Old 04-19-2010, 09:32 PM
SJMMFGINC's Avatar
The line lock inlet/exit ports are 1/8" NPT. They are not inverted or bubble flare.
It sounds like you're building your own personalized setup as our ABS kits come pre-assembled. If you've purchased the line lock solenoid independently, directions should have been included describing the ports.
Washers are not necessary as mentioned above.
Feel free to call or e-mail us if you have further questions. We can help you with any fittings you'd need.
Hope this helps,
Steve
Mechanical Engineer
SJM Manufacturing Inc.
724 478 5580
Old 04-19-2010, 10:00 PM
daniel6718's Avatar
i got it...use a brass fitting male to female on the other end to seal it off then used a regualr 1/8 inch fitting with a flare to seal into the brass fitting...looks like it will work fine!
thanks
Old 04-19-2010, 10:49 PM
SJMMFGINC's Avatar
Good job! Good luck with the setup!
Quick Reply: sjm line lock how to seal
