Stud Holes
Stud Holes
Ok, so I have swapped out my 10 bolt for a 12 bolt Moser. From Moser, I had them put in the factory studs in the hub.
Now I put my new rotors on and notice there are some hell-of-a gaps around the studs and at all different locations, its not uniform overall, some of the gaps are on the right side of a stud, then on another stud it is on the left and so forth.
So I didn't really look to see if it was this way on the 10 bolt & factory parts...however, now I have driven around for a while on the new rearend and all of a sudden I have two studs that are bent.
I measured the holes on the rotors, most are somewhere around a .612 range but they are all different.
If I buy new rotors, say from ATE or some manufacturer, will they be toleranced to the factory studs? instead of this mismatched that is causing me to have bent studs and improper/uneven loading on the studs?
Sorry, hope this helps
Ok, so the red circled parts are the rotor stud holes.
the holes for my studs ON THE ROTOR are WAY LARGER then my studs.
ALSO, the holes seem like they are not quite correctly offset either. In the YELLOW, you can for example see how my studs are positioned (for example), some are centered in the hole, with a large gap around them, and others are just touching on one side
when I bought the 12 bolt, i bought studs from moser that are factory size, which is 12 mm X 1.5 pitch commonly marketed as M12X1.5.
Which they did measure correctly to that spec, however my rotor holes are ~0.612 inches ----> 12mm is 0.472 .........so YEH.
well after examining my studs, i have several bent ones.
I think this is causing my bent studs, time for new rotors anyway...going to measure new rotor stud holes at parts store to ensure this.
That sounds possible.
The holes are usually a little larger than the studs but all the same. So if the stud is sitting on the left side of the hole on one, it should be that way on all. From the way it sounds, those rotors are not even close to that, sounds like they are designed for a different bolt pattern altogether.
What wheels are you running? I would look into something other than that to cause your studs to be bending.
well on the rim you can see where the rotor has slid/moved. wheel lug nuts are tq'd to 85 ft lbs. stock wheels. The rotor does sit correctly on the center piece of the axle, however the bolt holes are not all centered or all left side.
either this or when I tear it down, I have a stud hole or two that still has a small bur or burs in the holes in the axle.
according to your picture you have some studs that are against the right and some that are against the left size of the holes. If this is correct, then there is no way the rotor is shifting.
