Help! Fast 102 Install Now Strut Tower Brace Hits
Old 06-14-2010, 11:45 PM
ramairws6's Avatar
Default Help! Fast 102 Install Now Strut Tower Brace Hits
Well i went to put on my BMR Strut Tower brace today after buttoning up my Fast 102 LSXR install and came to find out it doesn't even come close to fitting back on! Anybody run into this issue? What's a guy do now? I really would like to put it back on because it does help alot. I've looked at all the other ones out there and they all look the same. Is this too new of an issue? Help!??
Old 06-15-2010, 10:53 AM
shiv15's Avatar
I don't have a solution for you, but I'm having the same problem. The only difference is solid motor mounts and a fast 90. If I set the SLP STB on top of the intake it will barely touch the top of the studs. I was hoping BMR would be tall enough but apparently not. What motor mounts are you using?
Old 06-15-2010, 11:19 PM
ramairws6's Avatar
I have the poly mounts and i have the exact same issue. The bar just barely touches the top of the strut tower studs. I wonder if any of the sponsors are aware of this issue or it's just to early in the game for this yet? I'm almost sure i would need at least an inch if not more but then it might hit under the hood? Not sure on this yet.........
Old 06-15-2010, 11:43 PM
Snake_Skinner's Avatar
Is this only a problem with BMR STB's or do alll brands of STB's do this with the FAST 102???
Old 06-15-2010, 11:50 PM
ramairws6's Avatar
Looks like all brands so far......
Old 06-16-2010, 01:08 AM
Pwebbz28's Avatar
No problem. Leave it off. That simple
Old 06-16-2010, 01:14 AM
SSmoken's Avatar
this. i mean does that thing even help lolz??
Old 06-16-2010, 01:49 AM
ramairws6's Avatar
I do think it pulls the wheelz straighter when the front comes up?? Who knows......
Old 06-16-2010, 08:06 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Try a Hotchkis?
Old 06-16-2010, 09:20 AM
z28bryan's Avatar
Does it really though???? How do you know for sure? Try it with it off and see what happens. Can't hurt right?
The front of our ls1 chassis right around there is pretty rigid. You might be fine. I don't have one.
Old 06-16-2010, 03:16 PM
Johnnystock's Avatar
Originally Posted by MeentSS02
Try a Hotchkis?
It fits on my FAST 92mm setup
Old 06-16-2010, 11:15 PM
ramairws6's Avatar
You don't have one, huh? So what kinda power do you put down and what are you running for times??
Old 06-17-2010, 01:23 AM
blakss's Avatar
maybe some sorta spacer but then the bolts might not reach. idk
Old 06-17-2010, 01:32 AM
93sspcoupe's Avatar
you could fab up a small spacer to go under the strut tower brace plates. it would be worth a shot anyway
Old 06-17-2010, 01:49 AM
When I unbolt mine to do some work, I immediatly notice a big difference in chassis flex when taking corner a bit hard.
Hotchkis FTW
Old 06-17-2010, 06:40 AM
ramairws6's Avatar
Tried that already but the studs are not long enough then.
Old 06-17-2010, 03:09 PM
peterlawl84's Avatar
can you replace the studs with longer ones? Sorry I didn't install my springs and shocks...so not sure if this is feasible...but if it is, you could run a longer bolt with a spacer, provided that there is enough clearance for the hood.
Old 06-17-2010, 06:06 PM
02TransAm/Batmobile's Avatar
Hotchkis FTW
Could be a placebo-effect happening. Who knows.
Old 06-17-2010, 09:23 PM
Black_Z28's Avatar
I 100% agree. Kind of like the people that say they can feel the difference when they added a CAI to their car.
4th gen cars really don't benefit from a STB. It's been talked about quiet a bit on road racing forums.
Old 06-17-2010, 10:29 PM
wabmorgan's Avatar
Originally Posted by pwebbz28
no problem. Leave it off. That simple
+1 ftw
Quick Reply: Help! Fast 102 Install Now Strut Tower Brace Hits
