tie rod ends and ball joint boots
I'm having trouble getting my new Moog outter tie rod ends to slip into the knuckle. Past the threads seems to be tapered out. Do I just need to bang-on it harder?
Also, I replaced the lower ball joints and the Moog dust boots won't seal right. Can I just silicone it down? I've read that the Moog boots should be replaced with energy suspension pieces, but can anyone help me with the part# ? Any help is appreciated. Thanks.
You shouldn't have to "bang" on them at all. Get the stud started through the spindle, and draw it in place with the castle nut. If it doesn't draw in easily and completely, you got the wrong part...maybe an incorrectly marked box.
If you go to the Energy Suspension website, they have a complete listing section for Camaro/Firebird parts.
Thanks. The tie rod end wont slip down enough to even get the nut on. I thought when adjusting for aligment they pull them out and turn, so I didn't see how forcing them in would work. Just my bad luck. I didn't go straight to Energy Suspension website. I'll try now. The Moog boots don't seat well and grease is already leaking out. I appreciate your help.
your probably trying to install the tie rod end the wrong way. The tie rod end is tapered and so is the spindle. They will only go together in one direction. I dont remember which way they go through the spindle on our cars, but I almost guarantee that is what is happening.
Well, I will ask then- from the bottom or the top? I started this project weeks ago and had other issues (replaced rack, had to get all bushings pressed)
BTW- someone respond, and if I am installing wrong- I will post so all can have a good laugh!!!
I'm hoping some of the TECH smarts you guys have are rubbing off on me cause I went out and did just that before I read your post - it's from the bottom- I am a complete fool. Any other newbs should learn from this- take pictures, do 1 side at a time (if possible, I couldn't)
THANK YOU 99345HP for not overlooking my complete stupidity, and THANK YOU leadfoot4 for responding before I bashed the hell out of it with a BFH and made things worse.
Thanks mitchntx - I'm slow - but you get the first laugh.
BTW- LS1TECH has really helped me- I've actually done a bunch of good work on my car with the info here.
Don't feel too bad, we all had to start somewhere. Sometimes I overlook the obvious, as I've been doing this kind of work for close to 40 years, and by now, it's second nature to me. What I'm getting at, is I never thought to confirm with you, that you were installing the rod end from the bottom.
Hafta bother you guys again. Can anyone give me the part# for the ES ball joint boot cover? I don't see a model specific listing, only universals. I'm trying to measure the Moog cover, but I would like to be sure. Thanks again
