Car wont hook!
Car wont hook!
Besides the stuff in my signature I have UMI subframe connectors, LCA's and panhard bar. I have my tires at 16lb psi and even after getting them really hot it will only hook every once in awhile. The *** end rolls to the left pretty bad. HELP!!!!
I have 75000 miles on the car. Not sure how many are on the shocks as I bought the car used. No I don't have a sway bar and it is not lowered.
Hello
Well not having a sway bar on the vehicle will not distribute the weight throughout the rear end. That is why its kicking the rear out. And I also noticed you are running a set of M/T Street Radials. Another thing to keep in mind they aren't a slick compound. Radial like air pressure I run mine around 26lbs and it seems to hook fine. So I would also suggest play with tire pressure and see what works well for your set up. If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
Hello
Thanks
Brad
Thanks
Brad
I thought you meant no rear sway bar at all. So the car has the stock sway bar installed?
A simple and inexpensive idea that would help greatly is a set of relocation brackets. The brackets help to plant the tires harder into the ground and are a great item for traction for under $100. Just a suggestion. Worn out shocks can contribute a little as well.
I have relocation brackets i just brought recently and before i installed them i was wondering how is it supposed to sit? Does front sit higher or is the rear of the bar supposed to be higher?
The relocation brackets are designed to lower the rear of the control arm, making the control arm higher in the front. If you have a lowered car the brackets are designed to level the control arm or have it slightly lower in the rear. If you look at the pictures in the below link they will help you install them.
www.umiperformance.com/2012
Hope that helps!
Hello
Thanks
Brad
Thanks
Brad
Pontiacerator
Before spending another dime, find a deserted section of road with relatively rough surface and incinerate those Mickeys into a smoke show. Then see how you hook.
I've found that the surface of the tires tends to harden after they sit around unused for a while. I'd go to the track and they'd spin without smoking when I attempted to burn out, and then fail to hook. Changing tire pressure didn't help. Now I make sure to go down to this closed road nearby and go to work every time before I go to the track ...
