Subframe Connector Install Problems
i just tried to put on my bolt on jegster SFC's and the rear LCA went on perfect with no problems but the front bolts were off by about an inch and could not figure out why. also on the mounting plate in the front part it has holes that are on the side of the bar but on my car there are no holes.
i had the front on my car on ramps and the rear on the ground but i heard on here that it can be done that way.
this is what i have. i got my own hardware for it
http://www.jegs.com/i/Jegster/550/40054/10002/-1
Yea I figured that. The only thing that I was missing that I have come to tind out I might need is the long bar nut bc there is no other way to get into the subframe and bolt it on.
I have locknuts, grade 8 bolts and some red threadlocker so the bolts are not a problem in my eyes
I have a set of the 3 point bolt in subframe connectors from UMI.. they are very nice.. just watch out for speed bumps
Send them back if you don't want to weld them in. If they are made for the car then it should fit.. try jacking up on one side more then the other.. your frame could just be really twisted. A inch is alot of twist>> but give it a shot.
Ebay them and buy a regular set from one of the sponsors
