Little comparison of sway bars
Just so you guys can see the difference here, I took a picture of my new and old sway bars.
From left to right, stock firebird/z28 (don't remember the size), 1LE 32mm, Strano 35mm, rear firebird/Z28, rear strano 22mm.
Just shows how much better the aftermarket pieces are.
Backs are easy with the **** that comes with the kit.
Fronts need an L 2.5 if I remember correctly. Sweep left to right = 1/4 turn. Before you do call Sam up and talk about goals, ride comfort levels vs performance gains and come up with a good front setting. Backs are easy to adj and can be run at full soft most of the time for comfort and quickly adj before some spirited runs. Everyone's level is diff you just need to find yours. Good luck.
LS1TECH Sponsor
The one with adjustment is the 22mm Adjustable bar. That's the non-adjustable bar. I have both.
__________________
LS1TECH Sponsor
Welcome to the club... amazing difference, ain't it? Enjoy, and if you have any questions, give me a call.
__________________
