UMI LCAs installed
UMI LCAs installed
hello
today i installed the UMI LCAs and relocation brackets,had no problems with the installation everything fittel perfect!
The car launches,accelerate better,rear feels more stable and more control during sideways i put the control arm in the lowest hole and good that i have the adjustable ones cause i had to adjust the axle a little.
Great products,great techical support (thanks Ryan!) and definitely worth the money
What's the purpose of having adjustable ones? I was advised to get the non-adj lower control arms so I'm wondering now if I will need them in the future?
EDIT: I just looked at the thread below this one and got my answer lol
You must have seen my thread, I was just going to post it up, showing my stock LCAs on relocation brackets have less tire clearance on one side.. I'll be ordering some within the next month or two... I'm getting closer and closer to having a full red UMI suspension setup under my car!
yeah i saw your thread,when i had my stock LCAs with the relocation brackets both my wheels were back like your passenger's side.
the right distance is the one you have at your driver's side.order a pair of adj LCAs and you'll be fine!
Yes, I did My rear was off center when I had the panhard bar installed, looks like I messed up buying the non-adj lower control arms because I want to lower it.
