Drilled/Slotted
Drilled/Slotted
I think this is the right place for this, if not, mods, do your thing. I bought my car with Drilled/slotted rotors on it already. Long story short, rotors got warped, changed the pads, now the brakes make a high pitched noise, even while not applied. When the brakes are applied the noise does get slightly louder, but it is NOT speed dependent. The noise im hearing does not get louder as I go faster. My question is, are there "certain" pads that these rotors need? The car did not make this noise before the new pads were put on.
pads dont warp, only rotors do. you can not turn drilled and slotted rotors. What kind of pad did you replace with? if they are ceramics give them a few hundred miles to break in.
Hello, you might try some ceramic pads if you put semi-metallic's on it.
Brake squealing is produced by high-frequency vibration in the brakes. With disc brakes, vibrations can occur between the pads and rotors; the pads and calipers; the calipers and mounts; and/or within the rotors themselves loose or missing anti-rattle clips, a good cleaning and inspection for loose or missing parts would be a good start too.
Permatex makes a product called disc brake quiet and can be found in most auto parts stores, did you apply any such compound to the back of the pads ??
hope this points you in the right direction and gives you a couple ideas.
good luck and keep us posted on what you find.
Wrong. Yes you can. I've done it lots of times on Brembos, Wilwood, etc.
To the OP, take your rotors to a competent machine shop and they'll resurface your rotors. If you just did a pad slap without cutting the rotors the glaze on the rotors combined with new pads will sometimes cause squeaking as you are experiencing.
Why people insist on using drilled and slotted rotor when they offer absolutely no benefits - and are actually less effective and safe than - blanks is unfathomable to me.
And removing even more material from an already-cut-down (and useless) drilled and slotted design simply means the rotors will heat up faster, be more likely to warp, and more likely to crack.
Like Jimbo98z said, why do so many high end performance cars come equipped with rotors like these if they're so useless as you claim?
Cracking due to cross-drilling can be minimized if the rotors are cast with the holes, rather than actually having them drilled, but you still create stress risers.
Why do the expensive cars have them? Same reason people with cheap cars have them - looks. Take a look at what the real auto-cross and road race guys are running - not cross-drilled and slotted rotors.
Taking .005-.010 off a rotor to clean it up isn't going to render it useless. Why do you think they crossdrill and slot rotors in the first place? Yep, to help cool down the rotor and increase stopping power. Less fade and less warpage occurs.
Cross-drilled and slotted aren't "useless" as in not functional - they simply provide absolutely no benefits, at all, for a car running anything approximating brake pads that are safe to use on the street, and honestly, I don't even think race pads outgas enough to warrant cross-drilled rotors anymore.
Why do so many road-race guys use blanks if the "big-name performance cars" come with cross-drilled rotors?
Cross-drilling and slotting has absolutely no benefits for a street car. Cross-drilling was done to allow race pads that outgassed under high temperature to keep from building a gas buffer between the pads and the rotors. Slots were used to constantly "refresh" the face of the pad. Neither have any use on a street car.
Cross-drilling has nothing to do with cooling the rotor - that's what the vanes in the center of the rotor are for - let alone decreasing warpage. Cross-drilling removes rotor mass, which removes heatsink mass, which means the rotors heat up faster, causing a much increased chance of warping, and the holes create stress points during heat cycling, causing cracks.
Irrelevant anyway, but the only picture you posted that actually has cross-drilled rotors is the Porsche. The M3 and ZR1 both have slotted rotors, which have already been discussed (pointless on a street car, used for a reason on a track car). Likewise, said slots have absolutely nothing to do with cooling the rotor, nor do they lend themselves to doing anything beneficial on a street car other than eating pads more quickly.
There are plenty of good threads about cross-drilled and slotted vs blanks in the suspension section, and plenty of good white pages on brake manufacturer sites if you want to read up on it. I'm going to /hijack before I get mod-slapped.
I love the discussion in this post..LOL. From what I have always researched to the original OP is that for strictly just a street car it's probably better to just get blanks unless you go to a high dollar cross driller/slotted rotor. Depending on the number of miles you have on your brakes I would try and take it to a reputable brake shop and see how much they can take off the rotor and see if the noise goes away. Your car already came with them so why not try that first. If it still is there then new rotors aren't that expensive for these cars. Just get all 4 new ones.
Thanks for the input.
drilled/slotted rotors cause less contact surface area between the pad and rotor...therefore causing less friction and worse brakes....that is as long as your not on a track heating up really hot...
