Eibach Pro-Kit or BMR Front Springs?
Old 09-26-2010, 01:09 PM
mesterious's Avatar
Default Eibach Pro-Kit or BMR Front Springs?
I have a 2002 Trans am WS6 and I did the heater hose mod in the back and need some front springs. Which one should I get?
Old 09-26-2010, 01:24 PM
99FormulaM6r's Avatar
I'd go with Strano's or BMR's. Why don't you get a whole set tho? BMR's and even the Pro-kit will lower about .75" or so more than the heater hose will in the rear. It seems like the mismatched rates won't do anything for your ride/handling either, but I could be wrong there.
Or, you could look into getting some Koni shocks that will improve the ride and handling of your vehicle and use the front lower perch with stock springs for about a .75" drop up front.
Old 09-26-2010, 05:30 PM
99Bluz28's Avatar
Another option is to get a set of Hotchkis 1" front lowering springs
Old 10-04-2010, 08:14 PM
Mike 02T/A's Avatar
I've got a set of the newer BMR front lowering springs, never installed. Decided to go with Afco Double-Adj shocks and springs up front. I could let them go cheap. Send me a PM if interested.
Old 10-16-2010, 10:26 PM
bongva's Avatar
i have BMR on my car right now, its not low enough for me so im switching out the fronts to the eibach pro kit.
Old 10-17-2010, 11:40 AM
SVThis's Avatar
is there a place to just buy fronts?
Old 10-17-2010, 12:44 PM
99Bluz28's Avatar
Hotchkis and BMR yes, you can buy new front springs from them, Eibach no.
Old 10-17-2010, 01:02 PM
rooster99ss's Avatar
Strano all the way man. I've never rode in a car with BMR's on it so I can't vouch for how they ride, but I switched to Strano springs from a Pro Kit and it was like the clouds parted and the angels started singing, LOL. 300% improvement in ride quality. It's probably my most favorite mod that I've done to the car
Old 10-17-2010, 07:39 PM
99Bluz28's Avatar
If you want a good set of lowering springs under $200, Google Vogtland lowering springs. Their the same company that makes Strano lowering springs, except the spring rates are different and there spring are progressive in rate.
Quick Reply: Eibach Pro-Kit or BMR Front Springs?
