Brake HELP!!!
Old 10-15-2010, 01:52 PM
Southtx's Avatar
Default Brake HELP!!!
I recently put on new slotted rotors and pads on my 01 Camaro SS. The front wheels started locking up. I then put on new front calipers, abs module, and brake lines, and it still does the same thing. I bleed the brakes already and the abs system with a Tech II. At first the driver side wheel would lock up worst than the passenger side, and now it's the opposite. I already spent more than I wanted to. If anybody has any idea what it could be, I would appreciate any suggestions.
Old 10-15-2010, 01:57 PM
Element's Avatar
Didn't happen to hit the sensor wires for the ABS sensors when you were changing stuff, did you?
Old 10-15-2010, 01:58 PM
metalmilitia606's Avatar
check your guide pins on your calipers they could be frozen
Old 10-15-2010, 02:00 PM
Southtx's Avatar
I don't think so. I dropped off the car with a mechanic yesterday, and he said more than likely it was the brake lines. He changed them and it's still doing the same thing. I'll call him and ask him if he's checked the sensors. Thanks.
Old 10-15-2010, 11:31 PM
wrencher
wrencher's Avatar
Is your ABS light on while driving it? Does it come on & go out once started?
Old 10-16-2010, 11:50 AM
Southtx's Avatar
Abs light is off. Mechanic said it's not giving him a code.
Old 10-18-2010, 06:21 PM
Southtx's Avatar
Thanks to everyone that responded. Got the brakes fix already. Had to replace the brake master cylinder.
Old 10-18-2010, 06:24 PM
joecar's Avatar
What did he say was the problem with the master cylinder...?
Quick Reply: Brake HELP!!!
