bad rear axle hop??
bad rear axle hop??
i have a 2002 ss camaro 6 speed. have alot of motor work done and suspension.. when i pop the clutch the car starts to burn out but the rearend hops so bad its rattling my brain up.. knocked a whole can of soda out of the cup holder.. anyone know why this is?.. much apreciated.. im a new member
LS1Tech Premium Sponsor
Sounds like you could use some good lower control arms along with some lower control arm relocation brackets. What kind of suspension do you currently have on the car, I am assuming it probably stock?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
hotchkiss rear sway bar and lowering springs hotchkiss tubular under hood,nitto tires centerforce 2 clutch.. ya i wa gunna replace the lower control arms next
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
With my old f bod ('83) I chased the bad wheel hop thing too- changed tires, shocks, turned out the LCA bushings were shot. Changing the bushings solved the hop issue, but my next and current ride I just upgraded the LCAs to tubular with poly rod-type (axle side) instead of trying to chase down higher durometer bushings and playing with an arbor press. BTW, my '83's rear grenaded shortly after a few nasty wheel hop instances... I'm not the only one reporting rear end failures due to bad wheel hop, so avoid pushing the car to the point of hop!
LS1TECH Sponsor
Lots of things can cause or contribute to wheel-hop. LCA's might be the issue, they might not. Shocks effect it, as does the torque arm (stock are flimsy stamped parts, and they aren't unknown to crack). Also the front rubber bushing (stock) allows the nose of the TA to move around a lot. And when bolted to the transmission that movement is added as well.
Might LCA's fix it? Maybe, but not always. Depends on if it's coming from the LCA's to start with, and contrary to popular opinion that's not always the case. I don't have any wheelhop while lowered without LCA brackets and with GM arms (though with the better solid rubber 1LE type bushings).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
