OEM Disc Brakes for 15 inch Wheels
What I am wondering is if anyone knows of any OEM disc brake set ups that will bolt onto 93-97 4th Gen cars! Seems to me that there have to be some caliper mounts and rotors that would work to make clearance for 15" Drag Wheels.
Joe
Joe
Joe
So you are saying that on an LT1 no grinding or spacer in the front and just slight grinding on the rear!
Joe
LS1Tech Premium Sponsor
Well, I am confused too because everyone seems to have a different opinion! Some say you have to run a spacer and grind, some say just a spacer and some say just grind front, rear etc.
Joe
Joe
Also, you'll probably want extended wheel studs out back because you'll be threading into the tip of the factory studs.
15-inch Pro Stars
- Kevin
