Need Some Decent Brakes
I need to replace my warped rotors, and throw some new pads on as well. I'm looking for some low cost, OE quality or slightly better pads and rotors for the front and rear. I have accounts with DBA, Powerslot/Stop-Tech, Roto-Tech, Brembo, etc., but looking to support some LS1Tech vendors. Thanks.
All those brands are decent for rotors. In my opinion, from a stopping imporvement, pads make the majority of the difference. Meaning a quality rotor but a crappy pad will not add much of anything. Go with a quality pad, like Hawk HPS.
Rotors all depends on your budget. I use brakemotive for the street with a Hawk HPS pad. For track days I use Centric blank rotors and Hawk HTC60s.
If you go with DBA's they are expensive and more than 'decent' brakes. Probably overkill for someone just wanting some improvement.
Thanks man. I was told similar by a BMW CCA race teacher that we have working for us. He said the Hawk HP10's? are the best pads out there, but love to eat through any finish on your wheels! Ouch...
I just e-mailed my rep for Centric/Powerslot/Stop-Tech. He said he's going to list me some options and prices. I'll most likely order through him at this point since pricing will be the best I'm sure. I appreciate your info!
All depends on what you want in a pad. HPS are great for street use, but not for a track. The HP+ are much more aggressive, but I don't like them on the street due to the amount of dust and the added noise. I've even had these fade on tracks too. HTC line is strictly for racing and I would not suggest them for street use.
Pick your parts for your application - sort of like a cam.
I've run many different pads over the years, I like the HPS best for street. I got tired of dirty chrome rims with the HP+. If I need an agressive pad, I can now switch them out quickly since I have a dedicated set just for the track.
Thanks again for the info. I spoke with my rep from Centric/Powerslot/Stop-Tech. Putting an order together through him. He stated:
"Note the 306 and 309 pads are the same compound. The 306 are marketed as Centric Fleet Performance and 309 as StopTech Street Performance. The front pad happens to be used in police pursuit vehicles which is why is marketed as Fleet Performance. These pads are perfect for what you want to do…street use and occasional track days. They are quiet, clean, and can handle a lot of heat (MOT 1400 degrees F)."
I think those sound fairly brilliant?
Thanks guys!
I ordered these StopTech/Powerslot/Centric rotors:
126.62013SL and SR (front slotted rotors)
126.62033SL and SR (rear slotted rotors)
& StopTech/Powerslot/Centric pads:
306.01540 (front pads)
309.04130 (rear pads)
2-3 weeks due to a b/o on one of the rotors.
I'll post up once they are installed.
