Do LCA relocation brackets really work?
i have adjustable torque arm, panhard bar and tubular rear LCA's. do the relocation brackets really make a difference? i have a M6 and was looking to make this thing hook alil better. would bolt in or weld in be better?
LS1Tech Premium Sponsor
Bolt-in is for 10-bolt rearends and are more expensive than the weld-in versions. They aren't "better" because it's the same part for more money, but it is a bolt-in that's pretty easy to install and it's powdercoated. They both will still accomplish the same job and you can always modify the bolt-in part to weld onto your next rearend you buy.
They are extremely effective at reducing wheel hop and increased anti-squat which helps the car launch. They're typically suggested for drag racing applications and are one of the best bang-for-the-buck mods out there.
- Kevin
- Kevin
Kevin - can you explain when to use one setting over another? I have the bolt-ins, but have never adjusted them since putting them on. I believe I'm in the lowest setting, but I'm not 100% certain till I get home and look.
- Kevin
Great thread. Not to hijack, however I do have a question and thought this would be a good time to ask it...
Would installing the bolt on LCA's on the lowest setting (on a stock ride height car) have an adverse effect on the car during road course driving? I'm trying to find a balance with my car between street driving, drag racing and road racing.
I know there's no perfect solution for all three, however it might be a worthwhile mod if it helps out with the street and strip traction and doesn't have a terrible effect on the road racing.
I never messed with mine. I kept mine at the lowest setting at all times. The middle setting is to correct the lower control arm angle once the car has been lowered and the lowest setting is for the performance advantage. I always just tell people to put them at the lowest setting for track use, and if they are concerned with binding, then go with a higher slot on the street.
- Kevin
- Kevin
Novice here when it comes to suspensions... always learning...
Thanks!
OK, cool. Binding is when the bushing is trying to be distorted from an irregular lateral force being applied. Lower control arms have a limited range of motion when there are polyurethane bushings installed versus a factory rubber piece. This is because the rearend is trying to rotate while the body of the car stays level. As an example, say you go over a large bump on the passenger side, but not the driver’s side. The passenger side of the rearend will try to move up with the bump, while the driver’s side will try to stay on the ground. This can cause a twisting on the bushing. Polyurethane flexes considerably less than rubber – which is its major performance benefit – but it’s also the reason why it binds. Where the poly might catch and impact the vehicle’s rotation, rubber will just flex and distort through the suspension motion. A way to easily get around while still increasing your vehicles performance is to put a rod-end on the rearend side so it will have a free range of motion, while a poly bushing on the body side will reduce some of the NVH (noise vibration and harshness). It’s the best of both worlds essentially.
Now how does binding impact your car’s road manners and handling? Well it’s a hard measurement, but it’s a simple fact that binding will act how a sway bar would and become an obstacle for the rearend to move in the path it wants to move. This can be a good thing and a bad thing. There is a lot of propaganda out there insinuating the worst outcome, but in all honesty, it’s not a major issue that plagues a daily driver or the recreational autoX and road racer. If your vehicle focus is on handling, I generally steer people away from our poly/ploy lower control arms to let the parts do their job correctly.
- Kevin
- Kevin
The downside to this comes in the handling department. You want a shallow angle in a handling application, but not so little that you cannot get the tires to bite. A rod-end on the rearend side helps out tremendously but if there is a polyurethane bushing on the rearend side, the problem is exacerbated greatly. But, the beautiful thing about LCA brackets is that it doesn’t alter your alignment. So you can run them on the street in the first hole to overcome the lost angle from lowering springs and then drop them down for the dragstrip. I personally left them at the lowest hole at all times and never really had an issue with it. However, everyone drives differently and it could be something you will change depending on how you’re driving.
- Kevin
- Kevin
1 Post
Thread revival here, but My car is lowered on stranos, and I have poly/poly BMR LCAs in, and I have a set of UMI poly/rod adjustable LCAs that I will put in when I get relocation brackets. For the relocation, if I mostly just cruise in the car on the street and drive it hard on occasion, what level do I put my brackets at?
My cat is lowered 2" in the rear, with the LCA's in stock position (up hill from body to rearend) the car would squat the rearend under heavy throttle. Worked halfway decent on the street for hooking, since i couldn't really hit it hard. but it would unload about 10ft out on the track.
I made a set of LCA brackets at work and welded them in mimicking the same design as many of the current available brackets out there:
1st hole: stock location (for line up purposes when welding)
2nd hole: 2" straight down (not in the arc of the LCA length since my car was lowered 2")
3rd hole: 3 down, arc angle accounted for.
I set them in the 2nd hole which mimics the "stock angle" now (slightly down hill from body to rearend) and the car hooks great on the track, pulls 1.4x 60's
Subsequently, it doesn't do as well on the street anymore.
