Air Ride/Ridetech questions
Old 04-13-2013, 03:37 AM
trevmust's Avatar
Default Air Ride/Ridetech questions
will ridetech fit onto aftermarket parts? or should I just powdercoat the OE **** so it lasts hopefully a long *** time. By aftermarket parts I mean control arms and a arms and such
Old 04-13-2013, 04:15 AM
99Bluz28's Avatar
Yes it will work with aftermarket parts, but stick with the stock upper arms up front for maximum drop.
Old 04-13-2013, 04:30 AM
trevmust's Avatar
the rear doesnt really matter though right since its on the rear end not any control arms? Even with a moser 12 bolt it should be the same right?
Old 04-13-2013, 10:41 AM
Skraight's Avatar
I just installed an AirLift/ridetech/bagriders frankenstein kit and it should work.
Old 04-14-2013, 09:11 AM
js2fst's Avatar
What is the deal with upper a arms
Old 04-14-2013, 12:30 PM
Skraight's Avatar
Also if you are installing a moser 12 bolt, I've seen other people say it raises the car an inch in the rear. Not sure how that would affect the cool ride kit.
Old 04-14-2013, 01:11 PM
99Bluz28's Avatar
Good point, also with the aftermarket rears you need to make sure the axle tub spring seat cups I.D. is at least 1.75" so the center of the Coolride airbag seat cup will fit within it.
Old 04-14-2013, 09:19 PM
js2fst's Avatar
So what is the difference on upper control arms
Old 04-14-2013, 11:42 PM
Skraight's Avatar
Some aftermarket upper A arm's will rub the air bag which will wear a hole in them.
Old 04-16-2013, 11:10 AM
js2fst's Avatar
What if you run the struts?
Old 04-16-2013, 12:08 PM
Skraight's Avatar
Which struts? The shockwaves?
Old 04-16-2013, 02:27 PM
99Bluz28's Avatar
93-02 F-bodies don't have struts.
With the 82-92 Yes, struts and no upper control arms.
Old 04-16-2013, 08:53 PM
js2fst's Avatar
Yes shockwaves sorry
Quick Reply: Air Ride/Ridetech questions
