custom xpipe torque arm
Old 10-29-2012, 09:19 AM
LeanPocket's Avatar
Default custom xpipe torque arm
what torque arm options do i have?
I saw a MWC torque arm that was made for true duals, cross member mounted?
UMI makes a torque arm that supposedly clears better than the stamped torque arm
idk what other options i have, lmk what you guys think. I have a custom x pipe that tucks up pretty good using tsp piping
Old 10-29-2012, 04:12 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
You can use our full length torque arms (adjustable or non-adjustable) with the Texas Speed true duals. What most of our customers do is they run the full length adjustable torque arm with our torque arm relocation transmission crossmembers. This give you plenty of clearance for the true duals and allows ample amounts of instant center adjustment and pinion angle adjustment. If there is anything we can do for you let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-29-2012, 04:55 PM
LeanPocket's Avatar
can you pm me pictures or post some pictures of them installed on a fbody with and without torque arm relocation trans cross member. I bought a bmr DSL and i really wasnt pleased with the clearance, however im happy with your relocation brackets.
Old 10-30-2012, 10:58 AM
LeanPocket's Avatar
bump.. any other sponsors?
Old 10-30-2012, 11:09 AM
BMR Sales2's Avatar
Our BMR driveshaft safety loop doesn't work with true duals which is why I am sure you weren't happy with the clearances. I do have guys that use our driveshaft safety loop with true duals but the true duals are custom built around the safety loop.
Let me see if I can dig up some pictures for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 10-30-2012, 05:05 PM
LeanPocket's Avatar
i had a y pipe setup with pacesetter lt's, the 3" pipe rested untop of the DSL so i had all kinds of vibrations and it was very thick type of crossmember so the height clearance wasn't ideal for me. It's just a DSL and only needed it for the track so im not a displeased customer or anything. The bmr relocation brackets havent bent and have done their job quite nicely.
if you could find pictures that would be great. This is the only complaint i have with true duals setup is the fitament of a nice torque arm.
Old 11-02-2012, 09:49 PM
dropedss86's Avatar
With this setup how much more clearance do you get over stock Torque arm.
Old 11-05-2012, 11:24 AM
LeanPocket's Avatar
would also like to know this
Old 11-08-2012, 10:13 AM
UMI Performance's Avatar
Thanks for considering the UMI unit, we appreciate it!
When we designed our 2205 torque arm it was designed around the TSP x-pipe.. we wanted to make sure it not only cleared the TSP system but also offered extra clearance to tuck the system up tighter, we can usually gain an extra 1". It should also work well with similar x-pipe systems.
I posted one installed picture below along with a link that has more picture to look at. The torque arm can been seen here- www.umiperformance.com/2205
More pictures HERE
Please let me know if we can help anymore. Thanks!
Ryan
Quick Reply: custom xpipe torque arm
