Weld on or bolt on lca relo. bracket?
Old 04-21-2004, 11:13 PM
1320_PERFORMANCE's Avatar
Default Weld on or bolt on lca relo. bracket?
I ordered me a set of weld on relocation brackets from bmr. last night I did a search on relocation brackets and all I heard was negative things about the weld on ones. alot of people had problems w/ the wheels not being centered in the wheel well. After reading all about the weld ons Im about to sell mines and get the bolt on ones. so what do you guys think? should I get the bolt on ones, or go ahead and weld em on. thanks in advanced.
Mark
Old 04-21-2004, 11:25 PM
steelsnow's Avatar
well i can tell u what happend to me. i got the boltons. bmr. talk about easy freeking instal!!! it was sooooo freekin easy. i did it with a spring and shock install so it was just a matter of sticking the re lo's on when everything was going back on. the only thing u have to do is cut a part on the car, but its very minor and its thin metal.
Old 04-22-2004, 03:16 AM
DARK AGE 53's Avatar
I would suggest you go with the BMR bolt-on's, helped install some on a friends SS a few years ago and they've worked perfectly over the years. If you just ordered them last night I'd see if you couldn't cancel that order and reorder bolt-on's. JMO
Al
Old 04-22-2004, 07:15 AM
Turo's Avatar
i have the bolt-ons, tehy were pretty easy to install, haven't had any problems with them
Old 04-22-2004, 09:06 AM
2w0s060's Avatar
I have the weld ins and have no issues, not BMR though, you can screw them up, I am sure pp have too. If you dont get the location with the LCA installed you can weld them to far back or foward. But really any normal person should be able to follow the instructions and install them with ease....
Old 04-22-2004, 10:48 AM
Moderator
jimmyblue's Avatar
You can weld the bolt-ons if you must, but they
are way beefy, as well as foolproof and removable
if you choose.
Old 04-22-2004, 12:29 PM
jd13's Avatar
I would go with the bolt ins. It's too easy to have the welder accidently bump the weld ins (like happened to me) and have them go in uneven. This resulted in some major tire rub and the wheels sitting uneven. I corrected it with some adjustable LCAs, but if I were to do it again, I'd go with the bolt ons then weld them in if I wanted that extra peace of mind.
Old 04-22-2004, 12:35 PM
SNAKSLYR's Avatar
I've had both. Had bolt-ons on the 10 bolt in the T/A. I got welded Spohn's for the Strange 12 bolt. The 01 SS has welded BMR's in it. The all worked well for us. The Bolt-ins are great for the 10 bolt. They should be all you need, but the 01 SS has it's 10 bolt in place. I think it makes all the difference to do one side at a time and have the rearend not move when they weld it in. That's where I think the wheel gap goes to hell for some. Hope this helps.
Will
Old 04-22-2004, 01:32 PM
Tranzor's Avatar
If you have a 10 bolt, I say get the bolt-ons... that way, if you ever decide to get a 12 bolt or 9" rear end, you can always sell the bolt-on relocation brackets and get some of your money back for them.
FYI, if you have a 12 bolt or 9", you'll need weld-ins anyhow...
Old 04-22-2004, 01:42 PM
Fulton 1's Avatar
Actually the BMR bolt-ins work just fine with the Strange 12-bolt:
Old 04-22-2004, 02:01 PM
Tranzor's Avatar
Ah... must be just the Moser then. I stand corrected.
Old 04-22-2004, 10:02 PM
SNAKSLYR's Avatar
Actually, I could not get them on my Strange. That's why I ended up getting the weld-in's.
Old 04-23-2004, 12:17 AM
Thanks guys, I sold the bmr weld ons to a friend and Im gonna be ordering my bmr bolt ons, I have the spohn LCA, willl they fit my bolt on relocation brackets?
While Im @ it I was gonna order my torque arm @ the same time, but Im undecided on 2. The bmr t/a or the random tech t/a. which would you guys prefer. thanks in advanced.
Mark
Old 04-23-2004, 12:50 AM
SNAKSLYR's Avatar
Yeah, the Spohns should fit fine. I have a Spohn T/A so no advice there.
Old 04-23-2004, 06:23 AM
I'm not sure about the Random Tech t/a but you'll want to order the longer bolt kit ( $19.95 ) from BMR if you're going with the BMR t/a.
Old 04-23-2004, 03:15 PM
snakslyr, which Spohn T/A do you have, do you have the Trans mounted one? if so how are you liking it.
Old 04-23-2004, 08:39 PM
2w0s060's Avatar
Well I paid $59 for my weld ins compared to $109 for the bolt ins. I figured for the extra $50 I wouldnt screw them up . But I do agree you can always sell the bolt ins if you sell the car.
Old 04-26-2004, 04:44 PM
SNAKSLYR's Avatar
No, I have the original type. I would have liked the trans mounted better I beleive. Lot's of noise with this one, But the rearend bites down hard with mine. I like it.
Old 04-26-2004, 05:00 PM
z2802sunsetls1's Avatar
i got bmr bolt ins work great for me
Old 04-27-2004, 09:53 AM
King James's Avatar
Which bolt "setting" are you guys using for stock height cars?
Quick Reply: Weld on or bolt on lca relo. bracket?
