Anybody lowered running LT's and duals?
Old 04-29-2013, 09:41 PM
BWZ_2k2Z28's Avatar
Default Anybody lowered running LT's and duals?
Anybody out there lowered, running LT's and duals? My car is a DD so I see all kinds of shitty roads and I just wanted to hear some opinions from people with a similar setup.
Old 04-29-2013, 09:55 PM
HoLLo's Avatar
Lowered on Hotchkis springs, with longtubes, 3" xpipe, into dual 3" SLP LoudMouth II mufflers. Plenty of ground clearance! I now have turndowns on them, and the clearance is the same. Just get a competent exhaust shop. My main problem is the xpipe is right under my torque arm.. If I ever put the car on a 4post lift, the torque arm and rear end weight pull the exhaust down and bend the hangers, so I have to bend them back to regain some clearance.
Hotchkis springs:
Old 04-29-2013, 10:24 PM
Zlow28's Avatar
as hollow said, a lot will depend on your shop and how well they manage to tuck it in the car.
Old 04-30-2013, 01:47 AM
roninsonic's Avatar
Put LT's and the Bassani TD's on my best friend's SLAMMED (a finger and a half between tire and lip) TA... PLENTY of clearance.
It all depends on the brand.
Old 04-30-2013, 02:00 AM
lemons12's Avatar
Bmr 1.25 springs and tsp dual were.. No issues.
Old 04-30-2013, 02:24 AM
GoodSpeed150's Avatar
Stranos and tsp duals. I have some trouble with speed bumps but for the most part it isn't that big of a problem. Love the look and sounds.
Old 04-30-2013, 09:42 AM
sscamaroburn02's Avatar
Stranos and tsp duals dumped and no issues. I took the time to adjust them and push them up high. Approx 4.5 inches clearance.
Old 04-30-2013, 10:08 AM
BrntWS6's Avatar
Kooks TD's slammed 1.25" and its not bad at all. Last time i got under the car I had one small scrape just before it goes over the axel.....which is the lowest part of my system. But my car is also not a DD...if I find a shitty road i'm turning around.
Old 04-30-2013, 10:22 AM
k_garretson23's Avatar
i was going to lower my car until I put on my tsp duals. I have pacesetter headers and granted they could go up more, I still do not think i will be lowering my car.
Old 04-30-2013, 10:59 AM
lemons12's Avatar
Slammed 1.25"??
Granted with my drag rim/tires i have absolutely no wheel gap.. But no matter the rim/tire combo Im far from slammed.
chewy99ws6's Avatar
Strano's and had TSP duals, only problem I had was it would scrape coming into my trailer
Old 04-30-2013, 01:29 PM
BWZ_2k2Z28's Avatar
wow I'm pretty surprised at the amount of positive results. The exhaust shop tucked my duals really nice. I went under the axle and the lowest part is the cats by like a 1/2 inch. So what springs would you guys recommend? I'm leaning towards the Stranos because of all the great reviews he has on here with Bilstein shocks. But I read somewhere on here that Bilsteins don't last on lowered cars. Any truth to that? Also, my car doesn't need to be lowered an awful lot to get rid of the 4x4 look so what do you guys think about the SLP Eibachs with the .75 inch drop?
Old 04-30-2013, 03:17 PM
HoLLo's Avatar
I would avoid the Eibach springs, seriously. My 97 came with their Sportline kit, which was WAY TOO LOW AND WAY TOO HARSH. I swapped them for a set of Hotchkis springs, which raised it up a bit, but still has the lowered look (see my pic above).. That car got totalled, and I kept the springs. When i bought my 01, it came with the Eibach Pro Kit, which was not quite as low or harsh as their Sportline kit, but still not a comfortable spring at all. I went right back to the Hotchkis springs and love them. I've used several kinds of springs, and been in different cars with different springs. My favorites have been these Hotchkis, BMR, and coilovers.
Old 04-30-2013, 03:22 PM
camaroz98's Avatar
glad to know im not the only one who messed up and ran sport lines, and good to here a good replacement for this pro kit i have right now.
Old 04-30-2013, 04:51 PM
BrntWS6's Avatar
Originally Posted by lemons12
Slammed 1.25"??
What you don't like my ricer terminology?
Old 04-30-2013, 05:01 PM
birner88's Avatar
This gives me some hope in lowering mine
Old 04-30-2013, 08:24 PM
BWZ_2k2Z28's Avatar
So how are Bilsteins with a lowered car?
Quick Reply: Anybody lowered running LT's and duals?
