Stock WS6 front sway bar on Z28 worth doing?
Old 06-30-2013, 03:31 PM
VandykeT/A's Avatar
Default Stock WS6 front sway bar on Z28 worth doing?
I've set my WS6 up to be a 99 percent drag car which means no front sway bar. My Z28 on the other hand is a 99 percent street car. Since I've got the front bar from my WS6 just laying around would it be worth it to swap over on my Z? I know its bigger but will I notice a difference? Thanks
Old 06-30-2013, 03:44 PM
Guitar's Avatar
You have it there...so why not do it?
Old 06-30-2013, 04:03 PM
VandykeT/A's Avatar
I planned on doing it I just wasn't going to get in a hurry to do it if it wasn't going to be a noticeable difference.
Old 07-01-2013, 09:16 PM
bad_408_vert's Avatar
Do it and let us know. Lol or send it to me and I ll try it out.
Old 07-01-2013, 10:05 PM
Empatho's Avatar
Since you already have it, might as well put it to good use.
Old 07-02-2013, 06:03 AM
bufmatmuslepants's Avatar
I noticed a difference, swap front could too since ws6 springs are higher rate also, I noticed a huge difference with both and bilstein hds
Old 07-02-2013, 07:09 AM
VandykeT/A's Avatar
I've all ready got Strano springs and Bilsteins on it. If its not raining when I get off work I think I'll stick it on there lol.
Old 07-03-2013, 12:19 AM
Zlow28's Avatar
You should feel a nice difference since its just the front bar.
Old 07-10-2013, 04:47 AM
My car was pretty neutral with the 32/19 combo, with a little push when things got serious around corners but very predictable and easily corrected with throttle input. Alot of guys use the 32/19 combo for road racing.
Old 07-10-2013, 01:41 PM
libertyforall1776's Avatar
Definitely do it.
For reference:
Sway Bars
RS/V6 stock is 28mm front, 15mm rear
Z/28 stock is 30mm front, 19mm rear
SS stock is 32mm front, 19mm rear
1LE SS 35mm front, 21mm rear
Strano 35mm front, 22mm rear
Quick Reply: Stock WS6 front sway bar on Z28 worth doing?
