wanna go lower!
wanna go lower!
I use my 02 trans am for occasional autocross days only.. its not a street car anymore, so I want to go lower... I have bilstien shocks with strano springs right now. what can I do to get lower without spending another 1000 bucks on coilovers... anyone cut their springs? I want this thing to look slammed
LS1TECH Sponsor
There is such a thing as too much of a good thing. Be careful.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Yeah, I get that. But you have to consider looks vs. how things work. I think a suspension should have some working travel left to, you know, work.
__________________
If you do end up going that route, you may want to consider increasing your suspension travel.. although I don't recommend it. If you do this, make sure you are taking all the right precations. If you were going to do this the right way, you might want to look into adjustable coilovers and weight jackers and put in a higher springrate... along with all the other stuff to support it.
FYI, the BMR 1" drop A-arms will not reduce the shocks compression travel. Furthermore it can easily be adjusted for less drop with spacers between the bottom of the shock and the A-arms. So he will still have the ability for some ride height adjustment up front if needed, and maintain the shock compression travel he has now. IMO, up front this is his best option while keeping the cost down. For the rear the Hose mod is a no-brainer.
