What would you recommend, Street Applications
Old 11-23-2013, 05:48 PM
02NavySS's Avatar
Default What would you recommend, Street Applications
I purchased my car lowered and had an issue with the rear passenger side saging about an inch. Instead of fixing the issue I'd like to change out the springs and shocks all together for street applications. I want to put long tube headers on and don't want to worry about crushing them however I love the lowered look. My wife and and both of my kids ride in the car as well so I need to take into account their weight so I'm not rubbing or bottoming out. The car is an 02 Camaro SS. What would you recommend?
Thanks,
John
Old 11-23-2013, 07:51 PM
nascarnate326's Avatar
Everyone is different.
DO NOT GET SPORTLINES.
Not that I got that out of the way, I think some Bilstein's, with BMR springs would nice for you.
Personally I elected to cut a little off my stock springs. Does everything I need it to do and was cost effective while looking great. Rides just fine if you stay on the conservative side.
Old 11-23-2013, 07:53 PM
trans_am7935's Avatar
You cant go wrong with BMR or Strano springs, they are both great, but BMR springs sit higher in the rear and have a slightly higher spring rate, they should take the rear passengers a little better, remember i said should.
Old 11-23-2013, 07:55 PM
ramair 1's Avatar
stranos would be a good choice ,only drops about an inch or so,
add some konis and call it done
Old 11-25-2013, 07:35 PM
02NavySS's Avatar
From what I can gather I currently have the pro eibachi springs on the car. They are black rather then red like the sportlines. If I stayed with these springs and went with bilsteins or koni struts would that fix my issue of the sag on the one side?
Old 11-25-2013, 07:48 PM
garygnu's Avatar
what for the christmas and new year sales .talk about your car at thanksgiving so your family gives you cash to use at the sales .
Old 11-26-2013, 12:02 AM
02NavySS's Avatar
As much as I'd like to wait this problem needs to be assessed. Loaded with the wife and kids there is a constant rub. After reading and further research it looks like I'm going to go with strano springs. I'm still looking into the best route for my application as far as struts. Car will not see the track much if at all...pretty much all street car.
Old 11-26-2013, 12:24 AM
QuicksterZ's Avatar
Koni's or bilsteins are also a good replacement
Old 11-26-2013, 09:09 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Not sure how much drop you are looking for, but our springs offer about 1.25" all around. Every car sits a little different based on weight, shock combo, etc. But we have had no complaints as far as ride quality with our springs
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-26-2013, 10:00 AM
z28bryan's Avatar
No the shocks won't affect the sagging. That's definitely the eibach springs which are known to sag. I think most springs end up leaning a little bit, but not nearly as bad as eibach.
Strano or BMR ride height territory, you will probably want a set of long tubes that tuck up pretty well. I have kooks which tuck up pretty well with strano springs. Riding around on the road never any issues with the headers bottoming out. You may get some rubbing though on a speed bump. I can usually avoid it if I am carefull.
Old 11-26-2013, 11:57 AM
02NavySS's Avatar
Thank you for all the replies, I will let everyone know what I went with!
Old 01-17-2014, 09:35 PM
02NavySS's Avatar
Konis did fix the issue...kept the eibach springs.
Quick Reply: What would you recommend, Street Applications
