Front Lower A Arm bushing measurement HELP!!
Alright guys I'm installing poly bushings in my 2002 Camaro SS. I had the common rear bolt rust welded to the inner sleeve of the bushing problem so heat was applied copiously lol anyway it goes without saying I burnt the rubber out and beat the h*!! Out of it to remove well in doing so I was unable to get an installed height measurement of the bushing to duplicate when I reinstall the new bushings...can a few of you guys with stock lower a arms mic the bushings and get some measurements for me so I can replicate whatever average you guys provide...thanks in advance I appreciate it.
If I'm understanding correctly from everything else I'm reading I should install them to the same width as the old bushings but being that I had to burn mine out I do not have a measurement...if I am confused I would appreciate someone explaining why according to GM service manual its says to get a measurement on the old bushing before removing...then install new bushing to the same measurement...
The bushing has a metal sleeve around it.press it into the arm so it's centered. That's all you have to do. I think you confusing yourself with the mounting if the arms to the kmember. That is slotted and needs to be put back in correctly or your alignment will be off. Either way you need a front end alignment after doing the bushings
Thanks undertow that makes more sense than a lot of what I was reading. The great the forums is when you say wtf other guys look at you like wtf. Thanks for clarifying. Would anyone happen to know where I can purchase the bushing cups in the control arms the mine aren't 100% shot but looking kinda rough thought it might be worthwhile to replace while I'm in there.
I hope you aren't trying to put poly in the caster (vertical) bushing of the lower A arm. Poly there can cause so much bind that people have actually broken the arm from that.
The other lower A arm bushing (horizontal, camber bushing) can be poly.
I don't think you can get just the shells. They come attached to the rubber bushings. Which again, do not use poly on that caster bushing!
