LCA relocation bracket Q?
For those of you who have installed relocation brackets, how did you hook up the e-brake? I have BMR brackets and there doesen't seem to be any way to hook up the e-brake other than cutting the connection off of the original brackets and welding them on to the BMR brackets.
I don't know if you guys understand what I'm saying. I installed BMR LCAs and there are no provisions for the e-brake cable that I can see. How do you hook up the e-brake cable?
You need to reuse the stock bracket but, you have to cut one of the arms off. Here are the direction with pics. http://bmrfabrication.com/instructions/cab001.htm
BTW: I cut the inside arm off but did not drill and bolt the back of the bracket. Mine is only held on at the one factory point left but the ebrake still works just fine.
I just cut my stock e-brake bracket off inboard of the little tab thingy and it was solid so I didn't do anything further. Its been working just fine for years now. The Sawz-All is your friend
Cool! Thanks for the help. I thought I would have to do something like that. Just making sure I wasn't the only one with that problem. Why doesn't anyone make the brackets with an e-brake bracket?
