Efffing BRAKES!!....
New pads
New rotors
Motive power bleeder
2 gallons pumped through with breaks to go up the street and activate the abs
Still have a spongy *** brake pedal and not so good brakes. WTF!!!!
New rotors
ditch the Motive power bleeder, seams like most the folks posting on here that are having your symptoms after bleeding have been using those, find a friend or family member to help and use the traditional bleed method.
What I did to totally flush my system was I got a bottle and a clear tube of proper diameter for the bleeder screw, ran the tube down into the bottle and opened the bleed screw and have him pump the brakes till fresh fluid came out (while checking the Master Cylinder and topping off as needed to prevent getting an air bubble), once clean fluid was coming out closed the screw, had him pump the brake then did a quick open/close on the screw. shouldn't take more then a 32 oz. bottle to flush the WHOLE car.
Reservoir cap is good and tight
Haven't taken the master off yet to see if it leaks but I can pump up and get hard brakes and leave it over night and it holds.
What's the correct order for our cars?
Get an empty Coke bottle with the cap, drill a hole in the cap to fit a 1/4 inch hose through. Make the hose about 2 feet long or 3 feet.
Pour brake fluid a 1/4 into the bottle and make sure the hose is in the fluid.
Open the bleeder and put the other end of the hose onto the tit of the bleeder.
Pump the peddle until there are no bubbles. Close bleeder and move to the next one.
You do not have to close the bleeder every time you pump the pedal. Do not let the system run dry do not let the hose in the bottom of the Coke bottle get uncovered while pumping the pedal.
No correct order needed.
Only thing is, I'd still go in the correct order (rear passenger, rear driver, front passenger, front driver). Just make sure the end of the hose is submerged in fluid and the end of the hose that goes on the bleeder doesn't fall off (use a small zip tie to hold in place).
