line lock pictures
Old 04-06-2014, 11:26 PM
LETZRIDE's Avatar
Default line lock pictures
Just looking for some pictures of how some of you guys have your line locks installed.
I'm swapping in my line lock from my 96 into my 02, but my setup in the 96 was a little sloppy.
Hoping to clean things up a little this time around, so how are you guys mounting your solenoids?
Old 04-09-2014, 02:40 PM
LETZRIDE's Avatar
so everyone buys pre-fabbed kits?
Old 04-09-2014, 07:33 PM
Moderator
thechef's Avatar
i made mine back in 02 before the pre fab kits came out, i will try to take a pic tomorrow
Old 04-09-2014, 09:39 PM
LETZRIDE's Avatar
thanks
Old 04-10-2014, 07:33 PM
YURVIEW's Avatar
Here's mine. Got deal on noid in classifieds few years ago. Used existing brake lines. Cut and reflared main line. Ran new line from noid to abs block. Need to straighten mine lines tho.
Old 04-11-2014, 08:47 AM
LETZRIDE's Avatar
Do you remember if it was a double or bubble flare going into the abs block?
I'm thinking I might just be able to snipe me a pre-flared line from the parts store and bend it to fit, or at the very worst do two flares.
I don't mind flaring lines, I ran completely new brake lines in my both of my other Camaros and in my buddies jetta...I just want to do this as quickly and as cleanly as possible though.
Thanks for posting that- it gave me a few ideas actually.
If I had the time and patience, I'd run brand new lines and take them through the inside of the car so that they don't ever rust out on you.
I actually know a guy with a mustang that did this and had the prop valve inside the car as well so that when he was on the road course and conditions changed he could change the bias of the brakes on the fly...kinda cool actually
Old 04-11-2014, 11:21 AM
YURVIEW's Avatar
They are double flared. I like the idea of vavle being inside car. May have to do that when I delete abs. Cool idea.
Old 04-11-2014, 07:10 PM
insidethreat07's Avatar
Pre fab from SJM
Old 04-12-2014, 10:26 AM
Firebirdmuscle's Avatar
Another sjm kit here slp noid.
Old 04-15-2014, 10:20 AM
PhantomR/T's Avatar
I bought the pre made kit from SJM and deleted the ABS, so my pics look just like the ones on their website. It's a nice setup.
Old 04-20-2014, 11:46 AM
libertyforall1776's Avatar
Not to hijack the thread, but is there an advantage to any one of the pre-fabricated kits -- SLP vs SJM? Are there others worth considering for an '01 F-Body?
Old 04-20-2014, 10:39 PM
LETZRIDE's Avatar
The only advantage to pre-fabbed kits is not having to spend 10 minutes measuring and then bending your own line and or flaring an end or two...maybe it looks a tad prettier.
At the end of the day if you install the lock properly it will function the same way pre-fabbed or not. I personally dislike unnecessarily spending money I could use on other modifications.
Old 04-21-2014, 04:12 PM
No, the SJM solenoid is rebuildable (not too likely to fail anyhow), where SLP's is not. Looks like SJMs has a lockout to prevent accidental operation with a master switch and momentary switch & LED activation light too. Found out SJM used to make SLP's up until around 2008...
SJM seems to be the way to go, they also have two mounting styles, I like the front mount.
SJM front mount:
SJM top mount:
Old 04-21-2014, 11:33 PM
LETZRIDE's Avatar
I have this one from jegs http://www.jegs.com/i/JEGS-Performan...rentProductId=
I would think that many of the units are rebuildable, but I could be wrong, I've never tried to take one apart, in any event they are pretty cheap on there own.
They safety switches are just that, switches, you can wire a lighter rocker switch inline with the momentary switch if you'd like and it is the same thing.
Here is the Jegs line lock I just installed on my car. I bent the line coming out of the master cylinder, and ran a separate line that I bent and mocked up myself from the lock to the abs block. I had to flare the line coming out of the master cylinder to a double flare and then the line going into the ABS block.
Wiring is easy, I just haven't had time to run it in this car yet. The hot side has a fuse in it, so if you were super worried about accidental use when not at the track you can just yank the fuse.
****Note, yes that is hockey tape holding the line lock in place at the moment. I am fabbing a bunch of things up with the rear currently out of the car. I'll be permanently mounting it shortly!! The wiring is also a mess; that just got buttoned up the other day and I have been sidetracked finishing up other parts of the car. I'll tackle wiring in the next week or so.
Old 04-26-2014, 08:56 PM
ta02zx10r's Avatar
Default line lock sjm/my custom setup
abs delete with proportioning valve
Here are some pics.
Attached Thumbnails line lock pictures-img_5098.jpg   line lock pictures-imported-photos-00012.jpg   line lock pictures-img_4172.jpg   line lock pictures-img_4186.jpg
Old 05-23-2014, 10:33 PM
Granatelli sells a kit too, didn't see any installed photos though:
http://granatellimotorsports.com/pro...it-132-42.html
Old 05-24-2014, 03:12 PM
BigDB's Avatar
All the pictures are awesome guys! I have a 2 step mounted where the top mount would go so I now know I would need a front mount kit. May I ask where everyone is putting the switch? and is it a momentary or a click on/off. I have 1 set of switches in my ash tray and another set above the radio so im gonna have to get creative
Old 05-25-2014, 10:38 AM
Supposedly to be NHRA-legal, it needs to be a momentary switch, I was told by the SJM engineer...
Quick Reply: line lock pictures
