SFC+LCAs+Shocks and Springs
Who makes the best for the buck SFC? Weld in or Bolt in, which is better?
Sorry im new to the suspension world.
Also, who makes the best LCAs?
Looking to drop 1-2". Which springs/shocks should i got w/?
Sorry for all the ?'s but rather then drag it all out, i figured id just through it all out. I have a 2000 triple black Z-28 w/ T-tops. Has SLP lid and LM.
I want the car to ride like it does now which is damn near perfect, or better. I dont want it to ride like ****, and **** up the camber and make the tires wear like **** and have to get realigned every ****** week.
Well I really like my SLP bolt in sfc's other will say go welded but the bolt ins work fine for me.
As far as springs try some Eibach with some bilstiens or maybe koni?? ( I like mine)
Also try using "search"
Weld in is the way to go. And in my opinion, I don't think anyone makes a better two point SFC than Globalwest Suspension does. I also suggest Eibach pro-kit springs, somewhere around a 1-1.25" drop. Eibach Sportlines are to soft and too low (for me anyways) and Bilstein HDs are great if you don't want to buy Koni's.
But realize your not going to get greatly improved handling with a car that floats around corners like a boat. Bilsteins and Eibachs will make your ride somewhat harsh, but are more than a worthwhile trade off I think. Once you get it aligned and set your camber, it's not going to change much or quickly unless you change some other suspension/steering pieces out (excluding huge potholes and the like).
Originally Posted by LS1ownzYOU
I want to drop the car, but in turn i dont want to scavenge its driveability now for looks. Id like it to drive like it does now, but about 1"-2.5" lower.
