what grease for poly lca bushings?
Old 05-25-2004, 06:53 PM
Turo's Avatar
Default what grease for poly lca bushings?
my spohn lca bushings are squeaking quite a bit and i was thinking of greasing them tomorrow. what grease should i use? is there one that i can get locally? thanks!
Old 05-26-2004, 03:36 AM
Judd's Avatar
Try regular anti-seize,,, works great.
Old 03-28-2005, 10:00 AM
11Second Club
Gauge's Avatar
Sorry to revive such an oldie, but at least it shows I'm searching... do you just grease these through the grease fitting, or do you have to take them off and grease the outsides of the bushing so they don't squeak against the bracket to which they're mounted?
Old 03-28-2005, 10:23 AM
EVILFACE's Avatar
I used marine grease. I smeared a little bit on each side of the bushing to slide it into place easier. Used the same grease in the bushing nib as well.
Old 03-28-2005, 11:56 AM
Judd's Avatar
I would apply anti-seize to the inner {where the sleeve goes through} and outer part {where the bushing contacts the LCA} of the bushing when I first put it together. I would then empty out a small grease cartridge {the best I could} and fill it with anti-seize. Then, every once in a while, I would shoot some in the zerk fitting. No kidding feller, anti-seize works great on poly.
Old 04-02-2005, 05:35 PM
JasonWW's Avatar
I second the marine type grease. It is designed to not be washed away by water. It's goodstuff. You can buy then in grease gun tubes as well.
Old 04-03-2005, 12:16 AM
OldeSkool's Avatar
mobil 1 makes a synthetic chassis grease
Old 04-03-2005, 03:44 AM
Mike K.'s Avatar
marine grease works great, get it at Wal Mart
Old 04-03-2005, 12:27 PM
JasonWW's Avatar
I've seen some warning labels that you aren't supposed to mix synthetic grease with "dino" grease. If it's true you might need to clean the old grease off to put the Mobil 1 stuff in. Just a guess.
Quick Reply: what grease for poly lca bushings?
