weight distribution
https://ls1tech.com/forums/suspension-brakes/162965-f-r-weight-distribution.html
It should be approximately 56.6% front, 43.4% rear
What are some worthwhile weight reductions you could do up front?
I could see moving the battery to the trunk, losing the A/C compressor and condensor/evaporator. Anything else that would add up?
I'm mostly just curious, I'm not trying to make a dedicated track car out of my Camaro. (yet )
Originally Posted by z98
An LS1 is about 53/47 (according to an actual scale).
That is all stock. With weight reduction up front you could easily get better than 50/50 distribution.
Originally Posted by John95Z28
If your LS1 weighs about 3600 lbs, and you measured 53% front / 47% rear, you'd have to add 108 pounds to the rear end while eliminating 108 from the front. Either that, or 216 pounds needs to come off the front. That would be quite a weight loss plan, considering that the AC only weighs 50 lbs, and a tubular K-member would take off another 40 pounds. Are you planning on a carbon fibre hood?
front 1750lbs -- 50.84%
back 1692lbs -- 49.16%
for a total of 3442lbs curb weight.
Originally Posted by technical
If you could manage to remove 158lbs from just the front you'd be at:
That's completely true, and at 50.8% on the front tires you'd be so close to 'perfect' weight balance that nobody could tell the difference. BTW, how much do you think that would improve autoX handling compared with stock? You should get less plow / understeer, but I wonder how noticeable it would be
Should be a noticable improvement when entering a turn. Probably need to pick different front springs since the car might sit higher.
Thanks guys!
I found this too after posting:
http://www.engine-power.com/pontiac/firebird_ws6.html
http://www.new-cars.com/2002/pontiac...fications.html
they both list 55/45 for firebird, 56/44 for trans am
z98- was it your car on the scale? just curious.
Not mine, a friends on 4 floor scales.
He was sitting in it and he had his nitrous bottle in the back full (20 lb bottle I believe).
It was 52/48. Not really that far from 50/50.
I said 53/74 because most people don't have a nitrous bottle in their back seat.
Why would it weigh 3600 lbs? Have you ever actually weighed one of these cars?
Don't forget A-arms, drag brakes, headers, relocate battery, !egr, !air, !bumper support, !power steering, !fog lights, wiring, !ABS module, skinnies, hood, etc etc.
Probably more if I actually thought about it.
Is that being sarcastic?
A-arms, drag brakes, k-member, skinnys, bumper support, move battery = goal
158lbs is significant weight especially if it was lost completely from the front of the car. Of course losing 150lbs from the front end might be tricky.
I was asking about weight distribution b/c i am interrested in handling, so that means no skinnies in front, and keep the power steering, ABS, and all that stuff. if it is between 50/50 and 55/45, then that is probably good enough for me. thanks again for all the info guys!
I saw a weight reduction list were everything added up to about 500 lbs, meaning you could have a sub 3,000 lb Fbody with 50/50 distribution. Although a few items on that list I'm not willing to remove. You can take a lot of weight of the nose by getting rid of the front bumper and replacing the battery with a lightweight version. Moving things to the trunk is not the best; may improve the distribution but won't help the angular moment of inertia (pendulum effect.) Better to place weight as close to the rear axle as possible, but stay between the front and rear axles.
I recently replaced the stock steering wheel and was shocked that it weighed 9.5 lbs (with air bag.) Aftermarket wheels are 2 lbs or less. Another good item to toss is the kick pannel under the gauge cluster . . . that thing is about 1/4 inch thick!
