How Noticeable Will An STB and SFC's Be When Put On At Same Time?
For my next mods, I plan on getting BMR's Xtreme STB and their SFC's. Since I don't plan on lowering my car ever, I'll probably go with boxed weld-in SFC's. When the STB and SFC's are all installed, how noticeable will their improvements be? I don't plan on doing any autocrossing, but I'd like to tie the chassis together and make it as strong as I can.
Exactly. I'm not sure how it'd be mounted with all the **** we have in our trunks, but a rear STB would be immensely beneficial I imagine, seeing as how we are hatchbacks.
Please think long and hard before buying the bulky weld-in boxed SFC's. If ever you do want to lower the car or you sell it to someone who does, you're stuck. There are a handful of good tubular SFC's (LG, GW, etc) out there that lose no ground clearance whatsoever. Another option would be the SLP bolt-ins, they're tubular, but can be removed if so desired. Just my opinion...
SFC's will make very noticeable difference in the tightness of the car. I had mine installed when the car was almost brand new and I immediately felt a nice improvement. I noticed a slight improvement in doing the STB (mainly in the form of quicker steering response and more "direct" turn-in - for lack of a better description), but not dramatic. Both are nice improvements though IMO, especially the SFC's.
I have this set up but for the convertible. You can't even see my sfc's. I noticed a HUGE difference. The car ride's really stiff without any flexing at all.
"Brick". Good or bad term?
Brian
Not saying the tubular designs are good, they are just as good. But I would not be afraid of running the Boxed style. I am very pleased. Im not a pro but thats my opion
Originally Posted by 2w0s060
I have the box style weld ins, lowered with no issues. On a TA your side skirts as well as most Y-pipes will hang lower then these SFC designs. As for the SLPs, as far as I know there Diamond style bolt in version hangs lower then the BMRs or similar design. Being the cross the chassis as they do.
Pound for pound the round cross-section will have better torsional rigidity than the square tube. So, I just don't see the need for a square-tube 2-point SFC (like the BMR) when a tubular design can be made to weigh less and tuck up better. The SLP design has a "double diamond" design which will add some more rigidity beyond the standard 2-point setup and they're a bolt-in design so they can be removed if so desired. Just my opinion. Just about any SFC will be beneficial on these cars in my experience.
I am just really pleased with the fit and feel of mine, I guess I like to brag
