Is 28.5 inches roughly stock ride height
Old 01-19-2017, 07:13 PM
Floorman279's Avatar
Default Is 28.5 inches roughly stock ride height
I think i remember reading somewhere once that the distance from the ground to top of wheel well front and rear on a 4th gen stock height is around 28.5. Obviously tires can change this. Just wondering if anyone can confirm
Old 01-21-2017, 01:58 PM
blackandgold's Avatar
They can all vary quite a bit. I think mine was more like 27.75, but it had 145k miles on the springs.
Old 01-21-2017, 03:45 PM
i figured that was the answer id get. i never measured before i did my viking install cause i was too anxious....was trying for roughly 1-1.5 inch drop due to my driveway and other opinions of those who are lowered. I'm trying for 27". so somewhere round 1-1.5 i guess.
Old 01-21-2017, 03:46 PM
i got the 28.5 number from that ride height after springs sticky. one said advertised "x" but realistically 2 inches. car measures 26.5 to the wheel wells. aka 28.5 stock.
Old 01-21-2017, 09:43 PM
jlangley's Avatar
My 01 SS was 28" rear and 27-3/4" front. All stock 70k miles.
Old 01-21-2017, 09:46 PM
another 27 3/4 vote. thanks.
Old 02-01-2017, 09:24 AM
Cammed95Z28's Avatar
I just measured mine because I'm doing a Viking Coilover swap this weekend and wanted to know the "before" baseline. Another 27 3/4 stock height here. 95 Z28 with 95,000 miles on the chassis/suspension.
Old 02-07-2017, 10:45 AM
Appreciate the response. Im sitting around 3/4 inch lower here. Let me know what u yhink of yours. Havent pushed mine yet but not decided how i feel.
Old 02-22-2017, 04:45 PM
I got the Vikings on this weekend. Ended up with the lock nut at only about 3 turns from the bottom in the rears which gave me a 1.5" drop from 28" in the rears to 26.5". I guess I won't really be able to go any lower than that, but it looks good and I'm happy with it. On the fronts, I've only completed the passenger side, but it looks like I'll have to be around 24 turns from the bottom with the lock nut to get her right where I want to sit. Much happier with where the spring sits on the shock in the front. I am tackling the final wheel this weekend and am not looking forward to the brake master cylinder! Since you have done this already, do you have any suggestions when it comes to that piece? (sorry to hijack your thread)
Old 02-27-2017, 12:00 AM
Pontiacerator
RevGTO's Avatar
You can safely unbolt the master and move it out of the way to access the torx bolts underneath it.
Old 02-27-2017, 05:40 PM
Yea what rev says. Dont be afraid to get a little rough with it....but not too rough
Old 02-27-2017, 06:35 PM
Thanks guys. Was able to install everything without a hitch and just got her back from getting a new alignment! Man this thing drives so much better with new shocks and springs! It squats/hooks noticeably better as well! Thanks again for the advice and help !
Old 03-08-2018, 11:22 PM
Mikeypooh1's Avatar
Congratulations on your new set of shocks and springs. I will be following the same route shortly. Still doing research for my best setup. After removing a “little” weight from the nose area, my car sits at 29.25” from ground to fender.
Old 03-09-2018, 07:13 AM
HCI2000SS's Avatar
What size tire do you run?
Old 03-09-2018, 10:19 AM
Crf450r420's Avatar
Measurements should all be from fender to center axle to be correct. What I found to be stock height is the body line is in line with the top of the rear tire and the middle lip of the front tire. I spent a lot of time trying to set for a stock ride height. I would have to measure to get you numbers, but I've found this visual way is a good way.
Old 03-09-2018, 08:12 PM
Mikeypooh1's Avatar
I’m currently running 235/55R17 all around
Old 03-09-2018, 08:23 PM
HCI2000SS's Avatar
Ok that explains why you're at 29" then. I was just curious
Old 03-09-2018, 09:33 PM
MY_2K_Z's Avatar
Wow those a skinny tires. I think a Prius has a wider tire than that.
Old 03-10-2018, 09:49 AM
Mikeypooh1's Avatar
Yeah that’s my problem. I’ve been close to wiping out a few times shifting from 2-3 and 3-4 tires breaks loose.
I’m in the process of looking for a nice set of wheels for a good price if not I’m going to go 255 at least for rear for now.
I’m limited to the 17x8.5 C5 thin spoke wheels.
Old 03-10-2018, 09:54 AM
Crf450r420's Avatar
Don't try Nexen 275's with 600+, based on how hard it is not to spin. I think they are only good for about 250HP with limited slip.
Quick Reply: Is 28.5 inches roughly stock ride height
