camber correction kit for ls1 f-body???
will the camber correction kit for the 82-92 f-bodies work on an 01 f-body? every place i called only has it for 3rd gens and dont have a kit for 4th gens listed, dont they have the same suspension set up anyway? any help is appreciated. thanks.
Kyle
Kyle
yes, when i lowered my car the camber was all outta whack so i was told i need to get a camber correction kit by the guy that does all my alignments. any other input.
Kyle
Kyle
I am still lost at that link all I saw was A-arms and stuff! Do you mean Bump steer kit! You need one of those when you lower alot? What do these part look like or go?
He is thinking of 3rd gen camber plates. No, they don't work on a 4th gen. You should be able to adjust the car as it sits. You may need to run more negative camber (it will handle better that way), but it will align when lowered. My car, lowered nearly 2", aligned just fine at that height. I set it to -1.3 camber, 4.5 castor and 1/32" toe out. I'd shoot for -.7 camber, 4.5 caster and 0 toe for street use (I drive mine daily and get 30K out of front tires).
Have fun!
Have fun!
