Why is my "brake" and "abs inop" lights on??
I just switched to prostars all around, and now whem I'm driving, my "brake" and "abs inop" lights come on. Any thoughts?? Thanks guys.
-John
-John
If the ABS unit sees a constant difference in tire rotation speeds, it begins to wonder if you are driving on ice, or if there is a problem, so it turns on the light. The ABS is designed for 4 tires of equal diameter, you no longer have that and the system won't work properly.
Exact same thing happened to me lastnight...last time my ABS INOP light turned on it was my rear speed sensors...but this time it happened when I put on all 4 of my prostars...and the BRAKE light is on as well...kinda scary for me not having my ABS working...n e one know of n e thing that can be done to fix that?
Originally Posted by warpwr
Oddly enough, Corvette's use unequal wheels and tires. Maybe there is some part swapping ability in there somewhere, somehow.
FYI, the OD of the tires and wheels on the C5 and C6 Vettes are different.
The ABS on the Vettes is designed for the different tire speeds, F-Cars the ASB expects the tires to be close to the same OD, so when the tires are majorly different +/- 1/2" the ASB thinks there is a problem.
The lights will come on if there is over .625-.750 difference in tire heights front to rear. - I think it actually depends on rollout but the heights are the easiest way to tell.
